Connection Cisco 2811 to internet (with dhcp ip from ISP)
skylunous
Good evening.
I just got a Cisco 2811 router and is trying to use it as a plain router for now. (Such as linksys)
Since my ISP is giving me address by DHCP.
I'm trying to connect FastEthernet0/0 by dhcp to the ISP
and setup NAT and DHCP on FastEthernet0/1 to give internet connections to each clients in LAN.
I think the DHCP setup was done and running.
But the NAT and ip routing seems to be some trouble.
I can't get clients in the LAN to connect to the internet.
P.S: The connection from the ISP comes out as RJ-45 Ethernetcable with DHCP.
So if it were other routers, I just plug it in and the setup would be done.
Here's my setup:
Current configuration : 1492 bytes
! Last configuration change at 03:15:17 UTC Fri Jan 7 2000
version 15.1
service config
hostname EIA-SERVICE
boot-start-marker
boot-end-marker
enable secret 5 (my secret)
enable password (my password)
no aaa new-model
dot11 syslog
ip source-route
no ip routing
no ip cef
ip dhcp excluded-address 100.100.0.254
ip dhcp pool service
   network 100.100.0.0 255.255.255.0
   default-router 100.100.0.254
   dns-server 168.126.63.1 168.126.63.2
no ip domain lookup
no ipv6 cef
voice-card 0
license udi pid CISCO2811 sn FHK1221F4K5
redundancy
interface FastEthernet0/0
 ip address dhcp
 ip nat outside
 ip nat enable
 ip virtual-reassembly
 no ip route-cache
 duplex auto
 speed auto
interface FastEthernet0/1
 ip address 100.100.0.254 255.255.255.0
 ip nat inside
 ip nat enable
 no ip route-cache
 duplex half
 speed auto
 no mop enabled
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
access-list 1 permit 100.100.0.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
end
My interfaces are like the following
EIA-SERVICE#sh int
FastEthernet0/0 is up, line protocol is up
  Hardware is MV96340 Ethernet, address is 001d.70a1.e330 (bia 001d.70a1.e330)
  Internet address is 14.53.252.222/24
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:03, output hang never
  Input queue: 0/75/53/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 7000 bits/sec, 16 packets/sec
     1323088 packets input, 79510587 bytes
     Received 1292581 broadcasts (0 IP multicasts)
     0 runts, 0 giants, 2 throttles
     93 input errors, 0 CRC, 0 frame, 0 overrun, 93 ignored
     0 watchdog
     36022 packets output, 2632208 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     1228135 unknown protocol drops
     0 lost carrier, 0 no carrier
FastEthernet0/1 is up, line protocol is up
  Hardware is MV96340 Ethernet, address is 001d.70a1.e331 (bia 001d.70a1.e331)
  Internet address is 100.100.0.254/24
  Half-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:02, output 00:00:02, output hang never
  5 minute input rate 1000 bits/sec, 2 packets/sec
     40603 packets input, 4760800 bytes
     Received 20170 broadcasts (0 IP multicasts)
     3 input errors, 0 CRC, 3 frame, 0 overrun, 0 ignored
     0 watchdog
     8797 packets output, 876205 bytes, 0 underruns
     1420 unknown protocol drops
NVI0 is up, line protocol is up
  Hardware is NVI
  Interface is unnumbered. Using address of FastEthernet0/0 (14.53.252.222)
  MTU 1514 bytes, BW 56 Kbit/sec, DLY 5000 usec,
  Encapsulation UNKNOWN, loopback not set
  Last input never, output never, output hang never
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 packets output, 0 bytes, 0 underruns
And, my ip route shows nothing.
EIA-SERVICE#sh ip route
Default gateway is 14.53.252.254
Host               Gateway           Last Use    Total Uses  Interface
ICMP redirect cache is empty
With regeards,
Thank you for your help in advance
in addition to the other post, you also have 'ip routing' disabled. Change 'no ip routing' to 'ip routing'.
Below is the revised config (changes marked in bold):
version 15.1
service config
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
--> ip routing
no ip cef
no ip domain lookup
no ipv6 cef
voice-card 0
redundancy
ip address dhcp
ip nat outside
--> no ip nat enable
no ip route-cache
duplex auto
speed auto
ip nat inside
no ip route-cache
duplex half
speed auto
no mop enabled
no ip http server
--> ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 dhcp
control-plane
line con 0
line aux 0
line vty 0 4
login
transport input all
end
5 Replies 5
a.alekseev
Level 7
Level 7
Remove "ip nat enable" from both interfaces
After that check your internet connection
Sh ip route
Sh ip nat translation
Done, and checked! (other settings are the same)
 ip address dhcp
 ip nat outside
 no ip route-cache
 duplex auto
 speed auto
 ip nat inside
 no ip route-cache
 duplex half
 speed auto
 no mop enabled
EIA-SERVICE#sh ip nat translation
EIA-SERVICE#show ip dhcp binding
Bindings from all pools not associated with VRF:
IP address          Client-ID/              Lease expiration        Type
                    Hardware address/
                    User name
100.100.0.3         0100.606e.b2cf.0d       Jan 08 2000 05:12 AM    Automatic
Still doesn't work for some reason.
I've checked the DHCP binding also, just in case I left something missing.
Any chance that static route may cause problem.?
And also, surprised to see no NAT translation at all...
I'll keep tinkering.
With regards. Thank you
P.S:As I went through, I also noticed the clock was wrong.
It is now fixed it by the way. But still wasn't the cause of the problem.
a.alekseev
Level 7
Level 7
conf t
ip routing
version 15.1
service config
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
--> ip routing
no ip cef
no ip domain lookup
no ipv6 cef
voice-card 0
redundancy
ip address dhcp
ip nat outside
no ip route-cache
duplex auto
speed auto
ip nat inside
no ip route-cache
duplex half
speed auto
no mop enabled
no ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
transport input all
end
Current configuration : 1460 bytes
! Last configuration change at 16:19:54 UTC Mon Jul 9 2018
version 15.1
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 100.100.0.1
no ip domain lookup
no ipv6 cef
voice-card 0
redundancy
 ip address dhcp
 ip nat outside
 duplex auto
 speed auto
 ip nat inside
 duplex half
 speed auto
 no mop enabled
no ip http server
control-plane
line con 0
line aux 0
line vty 0 4
 login
 transport input all
ntp server 203.254.163.74
end
Oh yeah, it's back on the track.
Thank you for all of your helps.
