10-05-2011 03:52 AM - edited 03-04-2019 01:49 PM
does anybody pls know any IOS capable to run MPLS on 1812?
I wanted to put an 1812 to my lab configured as a PE, but neither BGP address-family vpnv4 nor mpls ip interface command are available in the
c181x-adventerprisek9-mz.124-24.T, nor in c181x-adventerprisek9-mz.151-4 :-(
It's working with no problem on 1841 and the Software Advisor says it should also be available on 1812!?
Milan
Solved! Go to Solution.
10-05-2011 09:37 PM
Hello Milan,
The 1800fixed series (inc. c1812) does not support MPLS/MPLS-VPN.
On CCO you could check this at:
If Feature Navigator says it is supported - it is an error of FN.
In older 12.4(15)Tx train IOS CLI parcer allows you to configure it (at least in Adv IP Services fs).
So it could work for you, but is it not an offical support.
Sergey
10-05-2011 09:37 PM
Hello Milan,
Sergey
10-07-2011 02:21 AM
Hi Sergey,
you are correct, I loaded IOS c181x-advipservicesk9-mz.124-15.T9 to the router and at least the commands are available now !
So I'll test if they also work :-)
Thanks a lot,
Milan
