MPLS over GRE across Carrier MPLS
mdasher79
We're looking to extend our MPLS network across AT&T's MPLS network to a remote site.  Is it possible to use GRE tunnels to achieve this?  The Cisco document below specifically says MPLS over GRE across non-MPLS networks.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/mp_l3_vpns/configuration/xe-3s/mp-l3-vpns-xe-3s-book/mp-vpn-gre.html
Sergey Lisitsin
mdasher79,
That shouldn't be a problem The main thing to bare in mind though is you might need to lower your MTU to accommodate multiple additional headers. Other than that it should work fine. I have seen MPLS working without a glitch on GRE tunnel interfaces. I see no reason why these tunnels wouldn't be able to run on top of another MPLS network.
Sergey Lisitsin
mdasher79,
Awesome, thank you for the quick response.
