mpls pe and p function one the same device
burakdinci
Hello ,
Is it possible to configure mpls pe and p functions on the same router ? This router will run as p device for some connections and it will run as pe device for another connections. Could you give me information about this situation ? Kind Regards...
Burak
Giuseppe Larosa
Hello Burak,
this is possible.
a device is a P node if it is in the middle of an LSP.
It is a PE node or an edge LSR if it is the interface with outside world (out the MPLS cloud).
to be a PE the node has to take part in MP BGP.
Hope to help
Giuseppe
