07-27-2007 07:20 AM - edited 03-03-2019 06:03 PM
I have followed all of the configuration steps given for egress accounting with netflow on a MPLS VPN link. However, it is only showing flows coming into the router. I need to be able to account both ways- any recommendations? Config below:
interface Multilink12
mtu 1580
ip address XX.XX.XX.XX 255.255.255.252
no ip redirects
no ip unreachables
ip pim sparse-mode
ip route-cache flow
mpls netflow egress
mpls label protocol ldp
mpls ip
ppp multilink
ppp multilink group 12
ip flow-export source FastEthernet0/0/0.10
ip flow-export version 5
ip flow-export destination XX.XX.XX.XX 9996
IP packet size distribution (10730093 total packets):
1-32 64 96 128 160 192 224 256 288 320 352 384 416 448 480
.000 .098 .645 .011 .016 .012 .009 .010 .000 .001 .000 .001 .000 .000 .000
512 544 576 1024 1536 2048 2560 3072 3584 4096 4608
.000 .000 .000 .002 .185 .000 .000 .000 .000 .000 .000
IP Flow Switching Cache, 4456704 bytes
4 active, 65532 inactive, 464700 added
6109192 ager polls, 0 flow alloc failures
Active flows timeout in 1 minutes
Inactive flows timeout in 15 seconds
IP Sub Flow Cache, 336520 bytes
0 active, 16384 inactive, 20706 added, 20706 added to flow
0 alloc failures, 0 force free
1 chunk, 1 chunk added
last clearing of statistics never
Protocol Total Flows Packets Bytes Packets Active(Sec) Idle(Sec)
-------- Flows /Sec /Flow /Pkt /Sec /Flow /Flow
TCP-Telnet 7 0.0 20 233 0.0 7.0 11.3
TCP-FTP 3 0.0 1 40 0.0 0.4 1.6
TCP-WWW 5757 0.0 6 389 0.0 1.1 3.0
TCP-SMTP 7 0.0 1 40 0.0 0.7 1.6
TCP-X 244 0.0 1 54 0.0 0.0 1.5
TCP-other 304762 0.2 7 346 1.6 2.2 4.8
UDP-DNS 346 0.0 1 127 0.0 0.0 15.4
UDP-NTP 3323 0.0 1 80 0.0 0.0 15.4
UDP-other 131041 0.0 62 341 5.4 17.6 13.2
ICMP 64291 0.0 1 79 0.0 0.0 15.4
Total: 509781 0.3 21 341 7.1 5.9 8.3
SrcIf SrcIPaddress DstIf DstIPaddress Pr SrcP DstP Pkts
Mu12 10.50.66.218 Null 10.105.0.1 11 0675 00A1 84
Mu12 10.50.66.218 Null 10.105.19.10 11 0675 00A1 2
Mu12 10.50.66.218 Null 10.105.19.3 11 0675 00A1 4
Mu12 10.50.66.42 Null 10.105.19.10 06 0B3C 01BD 12
08-02-2007 10:32 AM
Use the bgp attribute-download command to enable the NetFlow BGP data export function. When attribute download is enabled, BGP downloads the attribute information for prefixes (community, extended community, and as-path) to the Routing Information Base (RIB) and Forwarding Information Base (FIB). This enables FIB to associate the prefixes with attributes and send the NetFlow statistics along with the associated attributes
08-02-2007 11:23 AM
I appreciate the update. It looks to me like this command is only for the 12000 series. We are trying to correct this on a 7507. Is there a similar command?
