MPLS VPN with multiple VRFs & PHP
Pradeep H A
Level 3
Level 3
Hi experts,
I am a beginner in MPLS VPNs & curious about IP packet forwarding happens with multiple VRFs. I have studied how MP-BGP & MPLS works with RD & RTs to create VPNs.
PE1-------------P1-------------P2------------P3-------------PE2
PE-1
VRF-A
VRF-B
PE-2
VRF-A
VRF-C
Suppose an IP Packet arrives at PE-1 on a VRF-A interface. It will be labeled to traverse the MPLS core to reach PE-2. But if that label will be popped at P3 due to PHP and the plain IP packet will be forwarded to PE-2. How will PE-2 know to which VRF the packet belongs?
Thanks a lot in advance
2 Accepted Solutions
Giuseppe Larosa
Hello Pradeep,
MPLS L3 VPN label advertised by MP BGP is used internally and it is never popped.
The external label is that of the LSP with destination PE2 loopback (called internal label by some authors) and this is the label affected by PHP.
This is given by the fact the BGP next-hop is the loopback address of PE2 by recursion.
MPLS frame for L3 VPN packet has the following aspect on wire:
MPLS external label |  BGP VPN label | IPv4 packet
This is called an MPLS label stack with depth = 2
The PHP action changes the MPLS frame into:
so only the most external label is popped.
So the BGP VPN label that PE2 has sent to all other PE devices in MP BGP is the discriminator for received traffic and PE2 can extract the IPv4 packet and can route it to the correct VRF with no issues.
Hope to help
Giuseppe
Hello Pradeep,
1)  >> Why there isnt remote-as statement for any neighbors except for those  in the global routing process & ipv4 vrf VRF-1 address-family?
The neighbor ... remote-as command is used to declare what is the BGP AS number used by the neighbor.
The configuration of a PE node like the one you have examined is an example of multiprotocol BGP MP BGP.
In MP BGP we define the neighbors with neighbor ...remote-as in router BGP configuration. The various address families like ipv4  unicast, ipv4 multicast, vpnv4 represent different areas of interest.
Each BGP peer can be interested only in some specific address families and not in all of them
The key command to tell the router that a specific neighbor is interested in address-family X is
the neighbor .... activate
command.
With this command we instruct the local node in sending and receving updates named NLRI ( Network Layer Reachability information) for the specific address family X.
2)
Following what is written above in MP BGP we move from the sending and receving of only IPv4 NLRI to multiple address families.
A neighbor that is activated only for address family ipv4 means a neighbor that is interested only in exchanging routes of type IPv4 unicast. This neighbor is not a PE node with VRF defined over it, so there is no need to send to it VPNv4 NLRI information.
The commands used under router bgp that are neighbor remote-as and neighbor ... update-source are those commands that define the properties of the BGP session to the neighbor like remote AS number and what address to use as source for BGP packets to be sent to the neighbor.
So these commands under router bgp are not dependent on the specific address family they define the BGP session properties.
In MP BGP for a given neighbor in addition to the commands under router  bgp at least one address family has to be activated with the command neighbor activate.
In other words in each address family the configuration elements that are present in router bgp are inherited and we just need to tell the router if the specific neighbor has to be activated or not in that address-family and to send the BGP communities or BGP extended communities
Hope to help
Giuseppe
8 Replies 8
Giuseppe Larosa
Hello Pradeep,
Hope to help
Giuseppe
That helped a lot Giuseppe...
But now I again get a couple of doubts...
1. Does all the IP packets & routes belonging to one VRF have the same BGP VPN label?
2. How can I check which BGP VPN label is assigned to what VRF on PE? What is the show command?
3. I asume BGP VPN labels are carried only in VPNV4 address-family updates & not in IPV4 address-family updates. Correct?
Hello Pradeep,
1)  default behaviour for Cisco implementation is to use a different label for each VRF IPv4 prefix a per VRF label can be configured at least in some platforms for scalability purposes
2)
show ip bgp vpnv4 labels
see
http://www.cisco.com/en/US/docs/ios-xml/ios/mpls/command/mp-s1.html#GUID-6D47C40E-95D0-49E2-A1A9-7BCBC3E9A13A
3)  Yes the BGP VPN label is an attribute of a VPNv4 NLRI
Hi  Giuseppe,
On one of our CE routers I noticed we have VRF lite configured. There is only one vrf configured with a RD & RT but mpls is not enabled & the vrf routes are being advertised as ipv4 address-family routes.
1. In this kind of configuration I guess we cannot advertise the vrf routes as vpnv4 address-family since mpls is not enabled. right?
2. What is the use of RD when we using ipv4 address-family routes since RD are only used to convert ipv4 to vpnv4 addresses?
Hello Pradeep,
the VRF lite is a subset of full featured PE, it provide the capability to segregate networks in different VRFs but it misses the MPLS forwarding plane.
A logical dedicated topology has to be built to provide an exit point to each VRF. This is done with a different Vlan based subinterface or FR subinterface to the real PE node.
1)  in this case the router bgp process can be configured with one address family for each defined VRF. Within each VRF one or more standard BGP eBGP sessions can be setup towards the PE nodes
router bgp 65000
address-family ipv4 vrf VRF-NAME1
neigh x.x.x.x remote-as y.y.y.y
redistribute connected
no sync
2)
In  IOS when we configure a VRF a RD has to be provided it is mandatory also in the case of VRF lite.
In VRF lite the use of route targets is allowed to build forms of inter VRF communication that require configuration of the BGP process and of address-families associated to the VRFs even in cases when no external eBGP session is configured.
In other terms a VRF lite is a multi VRF device that is a device that is shared between different end customers that is able to provide logical separation between different customer networks using VRFs.
Hope to help
Giuseppe
Hi Giuseppe,
On one of our PEs I find this type of configuration:
router bgp ABC
----------output omitted---------
neighbor a.a.a.a remote-as ABC
neighbor a.a.a.a update-source Loopback0
address-family ipv4
neighbor b.b.b.b activate
neighbor b.b.b.b route-map deny_all out
address-family ipv4 mdt
neighbor c.c.c.c activate
neighbor c.c.c.c send-community extended
address-family vpnv4
neighbor d.d.d.d activate
neighbor d.d.d.d send-community both
neighbor d.d.d.d prefix-list deny_all_outbound_routes out
address-family ipv4 vrf VRF-1
redistribute static
neighbor e.e.e.e remote-as XYZ
neighbor e.e.e.e activate
neighbor e.e.e.e inherit peer-policy IPFR
neighbor e.e.e.e route-map TO_UNMANAGED_CUST out
1.  Why there isnt remote-as statement for any neighbors except for those  in the global routing process & ipv4 vrf VRF-1 address-family?
2. Address-family ipv4 vrf VRF-1 is for peering with CE routers in that VRF
    Address-family vpnv4 is for peering with other PE routers
     Then why some neighbors are configured just under "address-family ipv4"  without any vrf mentioned & also what about the neighbors declared  directly under the router bgp statement? what is the difference between  the updates sent to these neighbors?
Thanks a lot in advance!
Hello Pradeep,
command.
2)
Hope to help
Giuseppe
Hi Giuseppe,
Thanks a lot.
Your quick & comprehensive updates have helped me improve my understanding of MPLS & MP-BGP to a great extent.
