MPLS VPN with two CEs running OSPF area 0
Julio Garcia
Been having issues setting up mpls vpn -- specifically  involving ospf running between PE's and CE's, the remote site routes dont appear to either of the CE routers.
Diagram is attached,  both CEs are set up in ospf area 0 with the corresponding PE
I see the networks advertised by ospf to the respective PEs  and are in the vrf routing tables.
PE1:
O       114.114.0.0 [110/2] via 172.31.10.14, 00:33:58, FastEthernet0/0.781
PE2:
O       115.115.0.0 [110/2] via 172.31.30.14, 00:33:44, FastEthernet0/1.781
Both Networks also appear in the MP-BGP table in Both PEs , seems VPN is working okay:
PE1:
Route Distinguisher: 3:4 (default for vrf D)
*> 114.114.0.0/16   172.31.10.14             2         32768 ?
*>i115.115.0.0/16   1.1.1.3                  2    100      0 ?
PE2:
*>i114.114.0.0/16   1.1.1.1                  2    100      0 ?
*> 115.115.0.0/16   172.31.30.14             2         32768 ?
I also see the remote network in the ospf database for Area 0 in both CEs
CE1:
Summary Net Link States (Area 0)
Link ID         ADV Router      Age         Seq#       Checksum
115.115.0.0     172.31.10.13    4           0x80000001 0x0030C0
CE2:
114.114.0.0     172.31.30.13    517         0x80000002 0x00BA23
But nothing in IP routing table of either , i assumed that they would show up in IP routing table as (IA) routes -- but  dont see anything.
Would really appreciate if anyone can give me some pointers , relevant PE config below..
PE1:
ip vrf D
rd 3:4
route-target export 3:4
route-target import 3:4
interface FastEthernet0/0.781
encapsulation dot1Q 781
ip vrf forwarding D
ip address 172.31.10.13 255.255.255.252
no ip proxy-arp
ip ospf network point-to-point
router ospf 5 vrf D
log-adjacency-changes
redistribute bgp 10 subnets
network 172.31.10.12 0.0.0.3 area 0
router bgp 10
address-family ipv4 vrf D
redistribute ospf 5
no auto-summary
no synchronization
exit-address-family
PE-2:
ip vrf D
rd 3:4
interface FastEthernet0/1.781
ip vrf forwarding D
ip address 172.31.30.13 255.255.255.252
router ospf 5 vrf D
network 172.31.30.12 0.0.0.3 area 0
router bgp 10
redistribute ospf 5
no auto-summary
no synchronization
exit-address-family
Hey Rob,
Hmmm... Can you please try configuring this command on the CE1 in the OSPF process running over the VRF?
router ospf 1
  capability vrf-lite
In theory, it shoud not help but just to be sure... The point is that if an OSPF process is run in a VRF, it considers itself to be connected to the MPLS Superbackbone (a concept of OSPF/BGP cooperation in MPLS L3 VPNs). In other words, it considers itself to be an ABR. That causes reachability issues with inter-area networks because an ABR processes only those LSA-3 that are received from area 0. Also, it causes reachability issues with external networks because when BGP redistributes them from a VRF into OSPF, they get the "Down" bit set and as a result, they are ignored by other OSPF routers that also consider themselves to be connected to the MPLS Superbackbone to avoid redistribution loops.
The funny thing is that neither of these limitations should apply to you - you are running your routers in area 0 so the limitation about LSA-3 should not apply, and you do not indicate seeing the remote networks as LSA-5 but rather as LSA-3, so the Down bit should not apply, neither. In any case, let us make sure that I haven't overlooked anything in this logic.
Please try configuring that command on CE1, give the router some time and re-check the routing table if the network appears. If it does, ... I am going to press you for more information how that is possible, and if it does not, well, I will need to press you for more information as well
Best regards,
Peter
EDIT: The red lines claim incorrect facts and shall be considered as provably wrong. Please see my response below for corrected information. My sincere apologies for publishing misleading information!
6 Replies 6
Peter Paluch
Hi Rob,
Are you perhaps using VRFs and OSPF within these VRFs on CE routers as well? That could theoretically cause some reachability issues, although they would be more pronounced with external routes or if the area was different from area 0. Just checking...
In addition, can you please issue the following command on CE1 and post the result here?
show ip ospf database summary 115.115.0.0
Thank you!
Best regards,
Peter
Hi Peter,
Thank you very much for the reply
You are right , i am using vrf lite on the CE edges just so i could keep the routing tables on the CEs a bit separate.
here is the output of the command on CE1:
            OSPF Router with ID (199.0.0.1) (Process ID 10)
            OSPF Router with ID (172.31.10.14) (Process ID 1)
  LS age: 553
  Options: (No TOS-capability, DC, Downward)
  LS Type: Summary Links(Network)
  Link State ID: 115.115.0.0 (summary Network Number)
  Advertising Router: 172.31.10.13
  LS Seq Number: 80000002
  Checksum: 0x2EC1
  Length: 28
  Network Mask: /16
        TOS: 0  Metric: 2
Hey Rob,
router ospf 1
  capability vrf-lite
Best regards,
Peter
Hi Peter,
Thank you for the amazing  help , works now after the vrf-lite command put in
very much appreciated!
Rob,
I take back what I wrote because that is a gross inaccuracy. The capability vrf-lite should help in your case
Quoting from
http://www.cisco.com/en/US/docs/ios/iproute_ospf/command/reference/iro_osp1.html#wp1012376
Table 1     PE Checks Performed
Type-3 LSA received
The DN bit is checked. If the DN bit is set, the Type-3 LSA is not considered during the shortest path first (SPF) calculation.
Type-5 or -7 LSA received
If the Tag in the LSA is equal to the VPN-tag, the Type-5 or-7 LSA is not considered during the SPF calculation.
So for LSA-3, the Down flag (also shown in your output) is what counts, and for external LSAs, the route tag is important.
I apologize for publishing misleading information before.
Best regards,
Peter
Thanks once again for the explanation  -- have a great weekend.
