MPLS vpnv4 l3 network I am not getting routes from CE Router
R Manjunatha
Level 3
Level 3
I created the VRF in PE router R38 AS5610 and similarly in PE router R35 AS 6520 and I configured the MP-BGP between the routes.
PE -R38 to CE-R76----- PE-R35 to CE-R82----
configured static route and redistributed to BGP
I am not getting the BGP route (82.82.82.0) from PE-R38
R38#sh ip route vrf F-1
Routing Table: F-1
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is not set
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 10.10.76.0/24 is directly connected, Ethernet0/0
L 10.10.76.2/32 is directly connected, Ethernet0/0
76.0.0.0/24 is subnetted, 1 subnets
S 76.76.76.0 [1/0] via 10.10.76.1
R38
interface Loopback0
ip address 38.38.38.38 255.255.255.255
interface Ethernet0/0
vrf forwarding F-1
ip address 10.10.76.2 255.255.255.0
duplex auto
interface Ethernet0/1
ip address 10.10.38.1 255.255.255.0
duplex auto
mpls ip
interface Ethernet0/2
ip address 10.10.33.1 255.255.255.0
duplex auto
mpls ip
interface Ethernet0/3
no ip address
shutdown
duplex auto
interface Ethernet1/0
no ip address
shutdown
duplex auto
interface Ethernet1/1
no ip address
shutdown
duplex auto
interface Ethernet1/2
no ip address
shutdown
duplex auto
interface Ethernet1/3
no ip address
shutdown
duplex auto
router ospf 1
router-id 37.37.37.37
network 10.10.33.0 0.0.0.255 area 0
network 10.10.38.0 0.0.0.255 area 0
network 37.37.37.0 0.0.0.0 area 0
network 38.38.38.38 0.0.0.0 area 0
router bgp 6510
bgp router-id 38.38.38.38
bgp log-neighbor-changes
no bgp default ipv4-unicast
neighbor 75.75.75.75 remote-as 6510
neighbor 75.75.75.75 update-source Loopback0
address-family vpnv4
neighbor 75.75.75.75 activate
neighbor 75.75.75.75 send-community extended
neighbor 75.75.75.75 next-hop-self
exit-address-family
address-family ipv4 vrf F-1
redistribute connected
redistribute static
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route vrf F-1 76.76.76.0 255.255.255.0 10.10.76.1
ipv6 ioam timestamp
mpls ldp router-id Loopback0
R75
interface Loopback0
ip address 75.75.75.75 255.255.255.255
ip address 10.10.32.2 255.255.255.0
duplex auto
mpls ip
ip address 10.10.75.1 255.255.255.0
duplex auto
mpls ip
ip address 10.75.75.1 255.255.255.0
duplex auto
mpls bgp forwarding
no ip address
shutdown
duplex auto
router ospf 1
router-id 75.75.75.75
network 10.10.32.0 0.0.0.255 area 0
network 10.10.75.0 0.0.0.255 area 0
network 75.75.75.75 0.0.0.0 area 0
network 75.75.75.0 0.0.0.255 area 0
router bgp 6510
bgp router-id 75.75.75.75
no bgp default route-target filter
neighbor 10.75.75.2 remote-as 6520
neighbor 38.38.38.38 remote-as 6510
neighbor 38.38.38.38 update-source Loopback0
neighbor 10.75.75.2 activate
neighbor 10.75.75.2 send-community extended
neighbor 38.38.38.38 activate
neighbor 38.38.38.38 send-community extended
neighbor 38.38.38.38 next-hop-self
exit-address-family
no ip http server
ipv6 ioam timestamp
R37
interface Loopback0
ip address 37.37.37.37 255.255.255.255
ip address 10.10.37.1 255.255.255.0
duplex auto
mpls ip
ip address 10.10.78.1 255.255.255.0
duplex auto
mpls ip
ip address 10.75.75.2 255.255.255.0
duplex auto
mpls bgp forwarding
no ip address
shutdown
duplex auto
router ospf 1
network 10.10.37.0 0.0.0.255 area 0
network 10.10.78.0 0.0.0.255 area 0
network 37.37.37.37 0.0.0.0 area 0
router bgp 6520
bgp router-id 37.37.37.37
neighbor 10.75.75.1 remote-as 6510
neighbor 35.35.35.35 remote-as 6520
neighbor 35.35.35.35 update-source Loopback0
neighbor 10.75.75.1 activate
neighbor 10.75.75.1 send-community extended
neighbor 35.35.35.35 activate
neighbor 35.35.35.35 send-community extended
neighbor 35.35.35.35 next-hop-self
exit-address-family
no ip http server
ipv6 ioam timestamp
R35
interface Loopback0
ip address 35.35.35.35 255.255.255.255
ip address 10.10.34.2 255.255.255.0
duplex auto
mpls ip
ip address 10.10.35.1 255.255.255.0
duplex auto
mpls ip
vrf forwarding F-2
ip address 10.10.82.1 255.255.255.0
duplex auto
no ip address
shutdown
duplex auto
no ip address
shutdown
duplex auto
no ip address
shutdown
duplex auto
no ip address
shutdown
duplex auto
no ip address
shutdown
duplex auto
router ospf 1
router-id 35.35.35.35
network 10.10.34.0 0.0.0.255 area 0
network 10.10.35.0 0.0.0.255 area 0
network 35.35.35.35 0.0.0.0 area 0
router bgp 6520
bgp router-id 35.35.35.35
neighbor 37.37.37.37 remote-as 6520
neighbor 37.37.37.37 update-source Loopback0
neighbor 37.37.37.37 activate
neighbor 37.37.37.37 send-community extended
neighbor 37.37.37.37 next-hop-self
exit-address-family
address-family ipv4 vrf F-2
redistribute static
exit-address-family
no ip http server
ip route vrf F-2 82.82.82.0 255.255.255.0 10.10.82.2
ipv6 ioam timestamp
control-plane
18 Replies 18
Gr8 ...I am able to see the BGP routes. what could be the issue
R35#sh ip route vrf F-2
Routing Table: F-2
10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
B 10.10.76.0/24 [200/0] via 37.37.37.37, 00:01:54
C 10.10.82.0/24 is directly connected, Ethernet0/2
L 10.10.82.1/32 is directly connected, Ethernet0/2
B 76.76.76.0 [200/0] via 37.37.37.37, 00:01:54
82.0.0.0/24 is subnetted, 1 subnets
S 82.82.82.0 [1/0] via 10.10.82.2
Your config was prefect,
only the router-id change
and as @Harold Ritter mention you add some command in VRF
NOW we need to force the BGP to accept the new change
and
clear ip bgp
and no bgp default route-target filter
do force the BGP to elect the best path and advertise it.
Hi @MHM Cisco World ,
Just applying the
in the PE  was sufficient. There is no need to clear bgp in this case.
Hi @R Manjunatha ,
The issue was due to the missing
address-family vrf F-1
under BGP as per config you posted before.
R35(config-vrf)#do sh run vrf
Building configuration...
Current configuration : 284 bytes
vrf definition F-2
rd 100:1
route-target export 100:1
route-target import 100:1
address-family ipv4
exit-address-family
vrf forwarding F-2
duplex auto
end
