MPLS vpnv4 l3 network I am not getting routes from CE Router
R Manjunatha
Level 3
Level 3
I created the VRF in PE router R38 AS5610 and similarly in PE router R35 AS 6520 and I configured the MP-BGP between the routes.
PE -R38 to CE-R76----- PE-R35 to CE-R82----
configured static route and redistributed to BGP
I am not getting the BGP route (82.82.82.0) from PE-R38
R38#sh ip route vrf F-1
Routing Table: F-1
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is not set
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 10.10.76.0/24 is directly connected, Ethernet0/0
L 10.10.76.2/32 is directly connected, Ethernet0/0
76.0.0.0/24 is subnetted, 1 subnets
S 76.76.76.0 [1/0] via 10.10.76.1
R38
interface Loopback0
ip address 38.38.38.38 255.255.255.255
interface Ethernet0/0
vrf forwarding F-1
ip address 10.10.76.2 255.255.255.0
duplex auto
interface Ethernet0/1
ip address 10.10.38.1 255.255.255.0
duplex auto
mpls ip
interface Ethernet0/2
ip address 10.10.33.1 255.255.255.0
duplex auto
mpls ip
interface Ethernet0/3
no ip address
shutdown
duplex auto
interface Ethernet1/0
no ip address
shutdown
duplex auto
interface Ethernet1/1
no ip address
shutdown
duplex auto
interface Ethernet1/2
no ip address
shutdown
duplex auto
interface Ethernet1/3
no ip address
shutdown
duplex auto
router ospf 1
router-id 37.37.37.37
network 10.10.33.0 0.0.0.255 area 0
network 10.10.38.0 0.0.0.255 area 0
network 37.37.37.0 0.0.0.0 area 0
network 38.38.38.38 0.0.0.0 area 0
router bgp 6510
bgp router-id 38.38.38.38
bgp log-neighbor-changes
no bgp default ipv4-unicast
neighbor 75.75.75.75 remote-as 6510
neighbor 75.75.75.75 update-source Loopback0
address-family vpnv4
neighbor 75.75.75.75 activate
neighbor 75.75.75.75 send-community extended
neighbor 75.75.75.75 next-hop-self
exit-address-family
address-family ipv4 vrf F-1
redistribute connected
redistribute static
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route vrf F-1 76.76.76.0 255.255.255.0 10.10.76.1
ipv6 ioam timestamp
mpls ldp router-id Loopback0
R75
interface Loopback0
ip address 75.75.75.75 255.255.255.255
ip address 10.10.32.2 255.255.255.0
duplex auto
mpls ip
ip address 10.10.75.1 255.255.255.0
duplex auto
mpls ip
ip address 10.75.75.1 255.255.255.0
duplex auto
mpls bgp forwarding
no ip address
shutdown
duplex auto
router ospf 1
router-id 75.75.75.75
network 10.10.32.0 0.0.0.255 area 0
network 10.10.75.0 0.0.0.255 area 0
network 75.75.75.75 0.0.0.0 area 0
network 75.75.75.0 0.0.0.255 area 0
router bgp 6510
bgp router-id 75.75.75.75
no bgp default route-target filter
neighbor 10.75.75.2 remote-as 6520
neighbor 38.38.38.38 remote-as 6510
neighbor 38.38.38.38 update-source Loopback0
neighbor 10.75.75.2 activate
neighbor 10.75.75.2 send-community extended
neighbor 38.38.38.38 activate
neighbor 38.38.38.38 send-community extended
neighbor 38.38.38.38 next-hop-self
exit-address-family
no ip http server
ipv6 ioam timestamp
R37
interface Loopback0
ip address 37.37.37.37 255.255.255.255
ip address 10.10.37.1 255.255.255.0
duplex auto
mpls ip
ip address 10.10.78.1 255.255.255.0
duplex auto
mpls ip
ip address 10.75.75.2 255.255.255.0
duplex auto
mpls bgp forwarding
no ip address
shutdown
duplex auto
router ospf 1
network 10.10.37.0 0.0.0.255 area 0
network 10.10.78.0 0.0.0.255 area 0
network 37.37.37.37 0.0.0.0 area 0
router bgp 6520
bgp router-id 37.37.37.37
neighbor 10.75.75.1 remote-as 6510
neighbor 35.35.35.35 remote-as 6520
neighbor 35.35.35.35 update-source Loopback0
neighbor 10.75.75.1 activate
neighbor 10.75.75.1 send-community extended
neighbor 35.35.35.35 activate
neighbor 35.35.35.35 send-community extended
neighbor 35.35.35.35 next-hop-self
exit-address-family
no ip http server
ipv6 ioam timestamp
R35
interface Loopback0
ip address 35.35.35.35 255.255.255.255
ip address 10.10.34.2 255.255.255.0
duplex auto
mpls ip
ip address 10.10.35.1 255.255.255.0
duplex auto
mpls ip
vrf forwarding F-2
ip address 10.10.82.1 255.255.255.0
duplex auto
no ip address
shutdown
duplex auto
no ip address
shutdown
duplex auto
no ip address
shutdown
duplex auto
no ip address
shutdown
duplex auto
no ip address
shutdown
duplex auto
router ospf 1
router-id 35.35.35.35
network 10.10.34.0 0.0.0.255 area 0
network 10.10.35.0 0.0.0.255 area 0
network 35.35.35.35 0.0.0.0 area 0
router bgp 6520
bgp router-id 35.35.35.35
neighbor 37.37.37.37 remote-as 6520
neighbor 37.37.37.37 update-source Loopback0
neighbor 37.37.37.37 activate
neighbor 37.37.37.37 send-community extended
neighbor 37.37.37.37 next-hop-self
exit-address-family
address-family ipv4 vrf F-2
redistribute static
exit-address-family
no ip http server
ip route vrf F-2 82.82.82.0 255.255.255.0 10.10.82.2
ipv6 ioam timestamp
control-plane
Hi @R Manjunatha ,
The issue was due to the missing
address-family vrf F-1
under BGP as per config you posted before.
R35(config-vrf)#do sh run vrf
Building configuration...
Current configuration : 284 bytes
vrf definition F-2
rd 100:1
route-target export 100:1
route-target import 100:1
address-family ipv4
exit-address-family
vrf forwarding F-2
duplex auto
end
18 Replies 18
Harold Ritter
Hi @R Manjunatha ,
It probably has to do with the import/export policy.
Can you share the
show runn vrf output from R38 and R35.
in R38
router ospf 1
router-id 37.37.37.37 <<- OSPF dual router-ID
network 37.37.37.0 0.0.0.0 area 0 <<-???
also as @Harold Ritter  mention the VRF route-target import/export must config
Hi @MHM Cisco World ,
The fact that R37 and R38 share the same router-id would be an issue if they were both part of the same AS, but they are not so it shouldn't matter.
 it's a typo error, Anyway, I change the router -ID
vrf details for R38 and R35.
vrf definition F-2
rd 100:1
address-family ipv4
exit-address-family
vrf forwarding F-2
duplex auto
end
R38#sh run vrf
vrf definition F-1
rd 100:1
address-family ipv4
exit-address-family
vrf forwarding F-1
duplex auto
end
R38#
Hi @R Manjunatha ,
The import/export looks good.
Can you provide the following commands output from R75 and R37:
show bgp vpnv4 uni all summ
When you change router-id
You need to clear ip ospf process to take effect
Yes. Default it will ask after changing router-ID and I have done it.
Please find the output from R75 and R37
R75#show bgp vpnv4 uni all summ
BGP router identifier 75.75.75.75, local AS number 6510
BGP table version is 1, main routing table version 1
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
10.75.75.2 4 6520 7 7 1 0 0 00:03:54 0
38.38.38.38 4 6510 6 7 1 0 0 00:03:38 0
R75#show bgp vpnv4 unicast all
R37#show bgp vpnv4 uni all summ
BGP router identifier 37.37.37.37, local AS number 6520
10.75.75.1 4 6510 8 8 1 0 0 00:05:19 0
35.35.35.35 4 6520 8 8 1 0 0 00:04:03 0
R37#
I configured the
no BGP default ipv4-unicast
on both the routers is there any issue with that?
Hi @R Manjunatha ,
This command just instructs BGP not to activate
address-family ipv4 uni
by default, which is what you want if you are strictly configuring VPNv4.
Hi @R Manjunatha ,
R37 and R75 are not receiving any routes from R38 and R35.
Can you please enter the following configuration:
R38:
router bgp 6510
redistribute static
exit-address-family
R35:
router bgp 6520
redistribute static
exit-address-family
An then "show run vrf" again from both routers.
please find the
show run vrf
for both the routers
R38#SH RUN VRF
Current configuration : 402 bytes
vrf definition F-1
rd 100:1
address-family ipv4
exit-address-family
vrf forwarding F-1
duplex auto
router bgp 6510
redistribute static
exit-address-family
end
R35(config)#do sh run vrf
vrf definition F-2
rd 100:1
address-family ipv4
exit-address-family
vrf forwarding F-2
duplex auto
router bgp 6520
redistribute static
exit-address-family
end
Hi @R Manjunatha ,
It should work now. Can you please check.
When you posted the
sh runn vrf
before, you were missing the
and
, which would explain why the VRF routes were not propagated.
I run lab and I success get connect prefix
no bgp default route-target filter <<-
remove this command and add it again
then clear
 ip bgp 6510 / 6520
