06-20-2014 10:12 PM - edited 03-04-2019 11:11 PM
Champs,
if MPLS WAN IP (PE-CE /30 IP)is conflicting with customer LAN IP , will it cause any issue? how to overcome this
V
06-22-2014 12:05 AM
In a /30 subnet you have 2 useable IPs, then y it is conflicting ??
Shijo.
06-22-2014 12:59 AM
If there is an IP conflict then the CE will output a log message telling you it doesn't accept the IP address on the other interface.Change your addressing to solve the problem.
Alain
