MTBF for Router 891
amoralc
Where could I find the MTBF information of this particular product? I am able to find info on other products from the 800 series but not on this one plus there are huge variance between them so Im insecure of picking data of a "similar" unit. Kind regards
Joseph W. Doherty
If Cisco documents it, it should be on one of the datasheets for tech notes for the device, but I cannot find its MTBF too.
That said, considering other 800 series start their MTBF at 200K hours and range from that to up to about 400K hours (one model even having a 1M hours rating). Further considering there's a tad less than 9K hours per year, and also assuming the 891 is likely also somewhere in the neighborhood of 200 to 400K hours, and lastly knowing MTBF is a statistical computation, (just curious) how important is knowing the actual MTBF?
Joseph W. Doherty
Thank you very much Joseph for your quick answer.
For your curioisity I was estimating the total reliability (failure rates on a period of time) of a system including these elements :)
