Multi Access Network
milkdroogy
Level 3
Level 3
what does this term mean? can you give me an example?
sorry for the noobish question
Richard Burts
Oren
A multi access network is a network which can have multiple (more than 2) machines participating in the network. A point to point network can have only 2 and a multi access network can have more than 2. The most common example of a multi access network is Ethernet (and FastEthernet etc).
Rick
Rick
Richard Burts
Oren
Rick
Rick
Thanks.
Edison Ortiz
Multi-Access Network is often referred to a shared medium, like a hub/switch where multiple devices can connect and share resources. In the WAN, you have Frame-Relay/MPLS/ATM networks where devices share the same Frame-Relay/ATM/MPLS switch.
