Multi-point L2TPv3 solution?
KGrev
Level 4
Level 4
Hi, I'm needing to span a flat vlan across multiple points with Cisco IR809G's at each location (over cellular cloud)
I am able to get one point to point link working with xconnect/l2tpv3. However I will need something that works for around 5 mobile locations. As i understand lt2pv3 only works for one link with an interface.
If you have a solution please be patient with me as I will have a few questions, I'm learning lol.
Thank you.
Giuseppe Larosa
Hello @KGrev ,
unfortunately there is no multi point L2TPv3 feature as far as I know.
However, replicating a VLAN L2 over cellular was prohibitive years ago for performance and costs.
Now with 50 GB per mounth contracts can be considered.
Try to check if you can use NAT instead or a routed solution that would be far better from performance point of view given also the type of routers involved.
Hope to help
Giuseppe
