Multi-VRF Route based VPN Support on AWS CSR1000v
JasonCran25184
Thanks in advanced for your time.
I am trying to configure a CSR1000v in AWS to have 2 customer side VRFs (VRF 70 and 71) and route based VPNs tied to each VRF. There is a remote gateway terminating the tunnels (it can handle the multi-vrf stuff on it's own side).  I want each VPN sourced from a different public IP on the CSR.
1. Is this design possible on a CSR? Meaning, can you have two VPNs in dedicated VRFs but point to the same destination VPN endpoint IP?
2. Do I need two separate fVRFs so as not to have conflicting default routes? Or is it just easier to use a couple static routes for the destination GW IPs?
Sorry for the crude drawing, just a quick example of what I need to do.
I configured everything with VRF aware configs but can't get the tunnels to come up and debugs don't provide a lot of direction.
Sergey Lisitsin
I can't see any problems with having two public IPs and having two tunnels to the same destination. If they are in different VRFs, then you are safe.
