Multicast being pruned when redundant routing switch goes down
vetle
I have a problem with multicast pruning.
There are 4 switches in total.
Switch 1 and 2 are layer 3 Catalyst 3650 and installed at one location, trunked together.
Switch 3 and 4 are layer 2 Catalyst 2960 and installed at another place, also trunked together.
Server 1 is connected to both switch 1 and 2, server 2 is connected to both switch 3 and 4 (bonding on both servers).
Server 1 is distributing multicast on several groups to server 2.
Server 1 is also receiving multicast on several groups from server 2.
Server 2 also distributes to and receives from server 1.
I have a problem where all multicast is pruned on switch 1 GE 1/0/22 when switch 2 goes down. It takes about 60 seconds before multicast is being received/distributed through this interface again.
Before this happens, switch 1 is already the PIM designated router. When switch 1 is PIM DR, and I shut down switch 1, the multicast is not pruned, switch 2 takes over just fine.
I tested with ping from server 1 to server 2 while shutting down switch 2, and I can successfully ping (only about 1 second downtime when I turn switch 2 off).
Server 1:
IP address: 192.168.208.21/24
Manually added route: 192.168.209.0/24 via 192.168.208.180
Server 2:
IP address: 192.168.209.33/24
Manually added route: 192.168.208.0/24 via 192.168.209.180
Any advice on troubleshooting, or obvious errors I have made, is appreciated!
See attached schematic on how the switches/servers are connected.
Here are the switch configurations:
Switch-1 config
ip routing
ip multicast-routing
no ip igmp snooping
spanning-tree mode rapid-pvst
spanning-tree portfast default
spanning-tree vlan 2 priority 24576
spanning-tree vlan 2 forward-time 4
spanning-tree vlan 2 max-age 6
track 10 interface GigabitEthernet1/0/22 line-protocol
track 20 interface Vlan2 line-protocol
interface GigabitEthernet1/0/1
switchport access vlan 2
switchport mode access
description HELLENIKON LINK
no switchport
ip address 192.168.209.181 255.255.255.0
ip pim dr-priority 8
ip pim sparse-dense-mode
ip access-group HELLENIKON_OUT out
standby 10 ip 192.168.209.180
standby 10 timers msec 250 msec 800
standby 10 priority 110
standby 10 preempt delay minimum 20
standby 10 track 20 decrement 10
interface GigabitEthernet1/0/23
switchport mode trunk
spanning-tree portfast disable
interface GigabitEthernet1/0/24
interface Vlan2
description INNOVA
ip address 192.168.208.181 255.255.255.0
ip pim dr-priority 10
standby 20 ip 192.168.208.180
standby 20 timers msec 250 msec 800
standby 20 priority 110
standby 20 preempt delay minimum 20
standby 20 track 10 decrement 10
ip access-list extended HELLENIKON_OUT
deny udp any host 239.192.32.100 eq 53105
permit ip any any
end
Switch 2 config
ip routing
no ip igmp snooping
spanning-tree vlan 2 priority 28672
no switchport
ip address 192.168.209.182 255.255.255.0
ip pim dr-priority 7
standby 10 priority 105
interface Vlan2
description INNOVA
ip address 192.168.208.182 255.255.255.0
ip pim dr-priority 9
standby 20 priority 105
permit ip any any
end
Switch 3 config
ip routing
no ip igmp snooping
interface Vlan2
 description INNOVA
 ip address 192.168.209.183 255.255.255.0
end
Switch 4 config
ip routing
no ip igmp snooping
interface Vlan2
 description INNOVA
 ip address 192.168.209.184 255.255.255.0
end
georgehewittuk1
Not sure how SW2 going down will affect the SW1<-->SW3 multicast control plane what is sending the prune message SW4? Have you debug ip pim on the 3 switches when SW2 is down.
What do the normal joins look like on all switches (show ip mroute) are their pim joins for this group for example from Server 2 as i could imagine there should be Server2 --IGMP--> Switch 3 ---- join ---> SW1---->Server1
