Multicast Lab
stephtchoko
Level 7
Level 7
Good day,
Plese can somebody help.I want to make a lab (bcmsn), where traffic multicast is transported.
I have the following material:
2 routers: cisco 2600
1 switch: catalyst 2950
Best regards.
pankajs
Level 2
Level 2
Put the multicast server on ethernet of one router.Connect 2950 to ethernet of other router. Put the multicast clients in different vlans on 2950 switch. After this you can use any one of the multicst routing protocols to get the multicast communication between the server and the clients.
Please do you know an sofware server muticast ?
Best regards.
psprice
Level 3
Level 3
You could try mcaster - look for mcaster.exe or mcaster.zip on google
Phil
