Multicast, Router Stops Responding
Thomas Beaver
We have a router that stops responding the SNMP polls during ghosting/heavy multicasting.  Its an older router, (2621) with the latest IOS available for the device.  I'm unfamiliar with multicast and not really sure why it does this?  Is it because the router is just old (Low CPU/Memory)?
ROUTER-1#show ip pim interface
Address          Interface                Ver/   Nbr    Query  DR     DR
                                          Mode   Count  Intvl  Prior
10.X.X.10      FastEthernet0/1          v2/S   0      30     1      10.X.X.10
ROUTER-1#SHOW RUN
ip multicast-routing
interface FastEthernet0/0
ip address 10.X.X.9 255.255.252.0
speed 100
full-duplex
interface FastEthernet0/1
ip address 10.X.X.10 255.255.255.0
ip access-group INTERNET-ONLY in
ip pim sparse-mode
ip igmp query-interval 100
ip cgmp
speed 100
full-duplex
ROUTER-1#show ip pim rp mapping
PIM Group-to-RP Mappings
ROUTER-1#
Reza Sharifi
Use command "sh proce cpu" during the ghosting and see how high the CPU utilization is
That will give you an idea what the issue is.
I'll give this a shot if I'm here when it happens again, but I'm under the impression the device could not be SSH'd/Telneted into during this time as well.
Device can't be accessed after multicast begins.  It locks up (but the workstations still receive the image) and we cannot ssh into the box.  Is this a CPU/Memory problem?
Are you sending your logs to a syslog server?. Maybe, that will help to find out what just happens when the Router stops responding andsee what what activity just took place. There are some tools like Solarwinds Cat tools.etc
HTH,
Please rate if helpful
