Router with High CPU Interrupt
cjinfantino
Hey all,
I  have a router that is running at ~37% CPU utilization with ~37%  interrupt utlization. I have verified that CEF is enabled on all  interfaces and that it is running. In addition I have followed Ciscos  troubleshooting guide http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00801c2af0.shtml
After  running some tests I am leaning towards a CEF problem. You will notice  that there is a high number of cache misses, and processed packets. I am  unsure if any of this matters though. I have read that a CPU utlization  of 10% or higher due to interrupts is bad but is it really?
Also, is it possible for HSRP to cause high CPU interrupt levels? Here is  some output from various commands. Any help is appreciated.
Thanks all,
CJ
show processes cpu sorted 5min
CPU utilization for five seconds: 36%/36%; one minute: 36%; five minutes: 35%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
  45      276544  85958342          3  0.08%  0.08%  0.08%   0 Per-Second Jobs
  73    51373292 410515501        125  0.08%  0.07%  0.08%   0 IP Input
  57         200       322        621  0.16%  0.15%  0.04%   2 SSH Process
  41     4582240  21976370        208  0.00%  0.03%  0.02%   0 Net Background
  16   1656608881548211510        107  0.00%  0.01%  0.01%   0 EnvMon
   5    24911736   8778295       2837  0.16%  0.03%  0.00%   0 Check heaps
   2       29948  17191665          1  0.08%  0.01%  0.00%   0 Load Meter
  95       33828 125805075          0  0.08%  0.01%  0.00%   0 CEF process
221     1178960  60383456         19  0.08%  0.00%  0.00%   0 HSRP IPv4
208        2112  85927351          0  0.08%  0.00%  0.00%   0 trunk conditioni
  11           0         1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  10          12   1432634          0  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  13        1328  85938723          0  0.00%  0.00%  0.00%   0 IPC Deferred Por
  12        2316  85938725          0  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  14           0         1          0  0.00%  0.00%  0.00%   0 IPC Seat Manager
   7           0         2          0  0.00%  0.00%  0.00%   0 Timers
  17           0         1          0  0.00%  0.00%  0.00%   0 OIR Handler
  18           0         1          0  0.00%  0.00%  0.00%   0 Crash writer
   8           0         2          0  0.00%  0.00%  0.00%   0 ATM AutoVC Perio
  20           0         2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
   9           0         2          0  0.00%  0.00%  0.00%   0 ATM VC Auto Crea
sho cef int
GigabitEthernet0/1 is up (if_number 3)
  Corresponding hwidb fast_if_number 3
  Corresponding hwidb firstsw->if_number 3
  ICMP redirects are always sent
  Per packet load-sharing is disabled
  IP unicast RPF check is disabled
  Inbound access list is 101
  Outbound access list is protectout
  Hardware idb is GigabitEthernet0/1
  Fast switching type 1, interface type 27
  IP CEF switching enabled
  IP Flow switching turbo vector
  IP Flow CEF switching turbo vector
  IP MTU 1500
<---omitted---->
GigabitEthernet0/2 is up (if_number 4)
  Corresponding hwidb fast_if_number 4
  Corresponding hwidb firstsw->if_number 4
  Inbound access list is not set
  Outbound access list is not set
  Hardware idb is GigabitEthernet0/2
  IP Feature Fast switching turbo vector
  IP Feature CEF switching turbo vector
  Input fast flags 0x400000, Input fast flags2 0x0, Output fast flags 0x10000, Output fast flags2 0x0
  ifindex 5(5)
  Slot 0 Slot unit 2 Unit 1 VC -1
  Transmit limit accumulator 0x0 (0x0)
  IP MTU 1500
sho cef drop
CEF Drop Statistics
Slot  Encap_fail  Unresolved Unsupported    No_route      No_adj  ChkSum_Err
RP      67456021           0           0   154587241           0           0
sho interfaces switching
GigabitEthernet0/1 description Primary Handoff-CentriLogic
          Throttle count          0
                   Drops         RP       3946         SP          0
             SPD Flushes       Fast     263432        SSE          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs    2880114      Drops          0
    Protocol  IP
          Switching path    Pkts In   Chars In   Pkts Out  Chars Out
                 Process  240646779 3075941537  179238873 4268814505
            Cache misses     791867          -          -          -
                    Fast 2738878053 1533579307 1501157067 4275204374
               Auton/SSE          0          0          0          0
    Protocol  DEC MOP
                 Process          0          0     142983   11009691
            Cache misses          0          -          -          -
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  ARP
                 Process       6012     360720       6002     360120
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  Other
                 Process          0          0    8595659  515739540
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    NOTE: all counts are cumulative and reset only after a reload.
GigabitEthernet0/2 To BTROC2-AS1 gi3/39
          Throttle count          0
                   Drops         RP          9         SP          0
             SPD Flushes       Fast         16        SSE          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs   34362050      Drops          0
    Protocol  IP
                 Process  175236306 2796785412  139274556 3033584364
            Cache misses  204911663          -          -          -
                    Fast 1655007830 3856814651 2708496561 3523926699
               Auton/SSE          0          0          0          0
    Protocol  DEC MOP
                 Process          0          0     142981   11009537
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  ARP
                 Process    2622647  157358820   58110943 3486656580
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  Other
                 Process       5539    2309763    8595566  515733960
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
show cef not-cef-switched
CEF Packets passed on to next switching layer
Slot  No_adj No_encap Unsupp'ted Redirect  Receive  Options   Access     Frag
RP   45187360       0           0        0 41702189     6726        0        0
meperuma
36% is interrupt, looks to me bad as some process raising interrupt constantly to the CPU.
do you see any abnormallty ?
if you  suspect HSRP, is it your HSRP configured with aggresive timers?
what kind of the box is this?
do you see the input Q is is increasing on the interfaces?, if yes, you can see  the punt packets of the interface using "show buffer input-in x/y"
if able to open a TAC case, they will do the CPU profiling to find what functions taking up your CPU.
May be can you post your config (remove any sensitve info)
shyshanm
If the CPU utilization due to interrupts was high for a long time, then it should be a concern.
The traffic across the network could play a role in this.
To determine which process is causing the high CPU, we could do the CPU profiling.
-Shyam.
