multicast VRF through global routing table
Johnson_Mo
hi team,
I have c9300 connected to SRX 340 via static route. I have also VRF on this switch with vrf default route through global. the VRF has  source multicast and needs to get out through global routing table.
VRF config
po11
no switchport
ip vrf forwarding  cust1
ip add 1.1.0.2/24
ip igmp static-group 235.1.1.1
ip pim sparse-mode
ing gi 1/0/1
des rp-VRF
2.2.2.2/24
ip pim sparse-mode
int gi 1/0/11
des src-mcast
192.168.1.1/24
ip igm sparse-mode
ip pim vrf cust1 rp-address 2.2.2.2 235.1.1.1
ip route vrf cust1 0.0.0.0 0.0.0.0 Port-channel1 1.1.2.1 global
po1
description Connection to srx 340
no switch port
ip add 1.1.2.2/24
ip pim sparse-mode
int gi 1/0/14
des rp-global
3.3.3.3/32
ip pim sparse-mode
ip pim rp-address 3.3.3.3  235.1.1.1
ip route 0.0.0.0 0.0.0.0 1.1.2.1
ip route 1.1.0.0 255.255.255.0 Port-channel1
when I do show ip mroute cust1 235.1.1.1
(*, 235.1.1.1), 1d04h/stopped, RP 2.2.2.2, flags: SPF
Incoming interface: Null, RPF nbr 0.0.0.0
Outgoing interface list: Null
(192.168.1.2, 235.1.1.1), 1d04h/00:02:53, flags: PFT
Incoming interface: GigabitEthernet1/0/11, RPF nbr 0.0.0.0
is it possible to leak or force VRF traffic including multicast to go through global?
thanks in advance
balaji.bandi
check some reference guide : (based on what IOS XE and License you have on Cat 9300 ?)
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-8/configuration_guide/ip_mcast_rtng/b_168_ip_mcast_rtng_9300_cg/configuring_vrf_lite.html#concept_ef1_qbq_s1b
BB
appreciate the response and article. my configs are based pretty much on the instructions in the article and still does not work. I was wondering if this is a limitation of 9300?
do the debug and also check other side.
BB
Hello
you static route towards the vrf cus is pointing to the wrong PC interface by the looks of it -
Also why are you showing different RP addressing?
maybe you could share a topographical diagram ?
Kind Regards
Paul
