multicast
ikizoo4
when i configure 3 multicast routers with auto-RP, can i configure one of them configure with static.
A.
basic Mcast configure
B.
configure as RP with auto-RP
ip pim send rp-annouce lo0 ----
ip pim send rp-discovery ----
C
configure B as RP
ip pim rp-address B ----
does this configure have any problem?
thanks
navarro1
Ensure router A interfaces which will forward/receive multicast traffic are configured for sparse-dense-mode. If you configure PIM in sparse mode or sparse-dense mode and do not configure Auto-RP, you must statically configure an RP. If router interfaces are configured in sparse mode, Auto-RP can still be used if all routers are configured with a static RP address for the Auto-RP groups.Another option is to enable the global configuration command [ip pim autorp listener], which causes IP multicast traffic for the two Auto-RP groups 224.0.1.39 and 224.0.1.40 to be dense mode flooded across interfaces operating in PIM sparse mode, and multicast traffic can operate in sparse mode, bidirectional mode, or source specific multicast (SSM) mode.
ip multicast-routing
ip pim send-rp-announce Loopback1 scope 16 group-list 1
ip pim send-rp-discovery Loopback1 scope 16
access-list 1 permit 239.1.1.0 0.0.0.255
int fa0/0
ip pim sparse-mode
thanks for answering...
i have another question.
there are mcast configureation with conditions as belows.
1. use sparse mode, it fail then use dense mode.
2. on the FR clould
3. use BSR
FR is consist with 3 routers 1 is Hub with mutipoint and 2 are spokes,,,
this FR is driving me crazy,,, i tried ip pim nb with ip pim sparse mode,,but still problem,,,any idea about mcast on FR cloud?
Configure the interfaces to use the NBMA software feature. This PIM feature allows you to configure a router to send multicast packets only to those neighbors that want to receive them. A router in PIM NBMA mode treats each remote PIM neighbor as if it were connected to the router through a point-to-point link. You enable the NBMA feature on a interface using the [ip pim nbma-mode] command. This will cause the router to track the ips of each neighbor when a PIM join message is received from that neighbor. In addition, the router will also be able to track the interface of the neighbor in the outgoing interface list, thus forwarding multicast data for specific multicast groups only to the neighbors that have joined the group. Keep in mind that NBMA mode does not support dense-mode, and the mapping agent must be able to communicate with all remote routers. You can configure the mapping agent on the hub router or another router behind it, but not on the remote routers. Also, ensure that you configure NBMA on all routers in the FR network:
interface Loopback1
ip address 10.1.1.1 255.255.255.255
ip pim sparse-dense-mode
interface Serial1/0
ip address 10.2.2.1 255.255.255.0
ip pim nbma-mode
ip pim sparse-mode
encapsulation frame-relay
frame-relay interface-dlci 1
frame-relay interface-dlci 2
If you can use point-point subinterfaces, this will be much better and you would not need to configure NBMA mode. This is the prefered method over a FR network.
Best Regards,
Francisco
