Multihomed ISP with 2 default routes.
abhishekpal
Hello
We are a multihomed ISP receiving just 2 default routes from Upstream ISP-1 and ISP-2. I have two LAN's which are advertised towards upstream ISP in the following manner -
1] network 11.11.11.0/24 is advertised towards ISP-1 ( preferred ) and also ISP-2 ( not preferred )
2] network 12.12.12.0/24 is advertised towards ISP-2 ( preferred ) and also ISP-1 ( not preferred )
Inbound traffic is well managed by using as-path prepending.
But how do I control outgoing traffic? Two default routes are installed in the routing table and I have changed the Local-preference of the default routes (the default route coming from ISP-1 is 150 and the default route coming from ISP-2 is 170 ), but in this manner, all forward traffic is going through ISP-2 ( quite natural ).
How should I change my BGP in a way so that network 11.11.11.0/24 traffic ( in+ out ) goes through ISP-1 and network 12.12.12.0/24 traffic ( in + out )  goes through ISP-2?  To be precise outbound traffic.
Requesting to help me out. Please do inform me if any part is unclear.
Thanks in advance.
Abhishek
11 Replies 11
pman
in - MED, AS-PATH
here is example with AS-PATH prepend:
ip prefix-list prepend permit 11.11.11.0/24
route-map prepend
match ip address prefix-list prepend
set ip as-path prepend 100 100
router bgp 100
neighbor <ISP-2 IP> route-map prepend out
out -
If you want to manipulate in such a way that network 11.11.11.0/24 will go through ISP1 and network 12.12.12.0/24 will go through ISP 2 then you can use PBR.
It is important to note that if you have decided to use PBR to perform the manipulation then you will also need to make sure that the next-hop (BGP peer / ISP p2p address) is available.
about BGP CONTROL outbound and inbound traffic:
Local Preference
used to manipulate traffic going out of your ASN This attribute is only exchanged with IBGP peers
Weight
used to manipulate traffic going out of your ASN but this attribute is local to the router
MED, AS-PATH
used To influence the inbound traffic path
about multihomed to Two ISPs Through a Single router:
https://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/13762-40.html?referring_site=bodynav#anc21
https://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/23675-27.html
Thanks for your feedback.
Applying PBR is of course a way out in this case ( next-hop of ISP-1 & ISP-2 is available with me ). But by applying PBR, will it be possible to achieve failover in case one ISP goes down?
If this can be done by using BGP, then BGP itself can take care if one path goes out of production.
Abhishek
about failover
When you configure PBR and set next-hop command the router will use the policy routing  as long the next hop is reachable,
if the next-hop is not reachable - i believe in this case the router will use its normal routing table.
if you decided to use PBR then i suggest you to check out the ip next-hop verify-availability feature
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_pi/command/iri-cr-book/iri-cr-s1.html#wp8093935770
https://www.networkbulls.com/ask/what-is-the-meaning-of-this-command-in-pbr-set-ip-next-hot-availability
OK, if this is the case ( if next-hop goes down, default routing behavior kicks in ), then PBR can be applied.
Abhishek
You can use PBR to control the traffic.
Hello
Do you have single or dual wan rtrs, I am assume the later as you mention local-preference, if so PBR wouldn't probably be viable.
If you do have dual wan rtrs do you have an IGP between them?
Are you receiving defaults by choice (meaning are you filtering other prefixes) or is it a sla between you and the ISP's
Kind Regards
Paul
I am having a single router connected to two different ISPs. We have actually instructed the upstreams to send us only the default route, as the router cant take the full routing table.
Abhishek
Hello
Okay then PBR would be viable.
FYI  local preference wouldn't be applicable in your design, You would use weight to manipulate egress  traffic.
Depending on what you monitor/track you may need to negate it from being seen via ISP2 connection
Possible example:
WAN RTR
ip sla 1
icmp-echo x.x.x.x source xxxx
frequency 5
ip sla schedule 1 life forever start-time now
track 10 sla 1 reachability
access-list 100 permit ip any 11.11.11.0 00.0.255
route-map PBR permit 10
match ip address 100
set ip next-hop verify-availability  (ISP 2) track 10
interface x/x
description LAN FACING
ip policy route-map PBR
Kind Regards
Paul
Thanks for your feedback. I will apply PBR.
But just i am curious - you have mentioned PBR like this -
Will it be like the above or as below-
access-list 100 permit ip  11.11.11.0 00.0.255 any
Abhishek
Hello
The extended acl is based on a source/destination ace so in this instance any traffic originating from that particular interface to that particular destination network (11.11.11.0/24)
so the acl reads
“any traffic for network 11.11.11.0/24”
Kind Regards
Paul
One note about using PBR and achieving failover. It is true that if the route to the next hop is removed from the routing table that PBR would use normal routing and failover would be successful. Since the next hop is usually on a connected interface this means that the route would be removed if the outbound interface goes down (line protocol down). There are situations where the next hop is not reachable but the  outbound interface does not go down, the route is not removed and failover would not be successful. To achieve successful failover you should include the verify-availability parameter in your PBR config. This link has helpful information about this feature
Rick
