Multilink Autofailover
Dear Experts,
i have one problem with Multilink.
i have two E1's of 2Mbps from my switch to Our Core Router. i had created a multilink between it. to improive connectivity speed to end users so i had created but. it was quite working fine for few days. suddenly one day one of the my E1 got down. so my totally multilink got down. and ping response was breaking so i had to remove multilink configs from it. and now its running with old configs.
please guide me how i can multilink this two link and create a bundle with autoswapping if one E1 get down then traffic should bot get affected it should go over antohter E1 and if that E1 came up then loadbalancing should happen.
awating your replies.
Nagendra Kumar Nainar
Hi Vivek,
It doesnt seems to be an expected behaviour. When you have multilnk PPP with 2 serail interface bundled, multilink should not be down if any one interface is down. Can you post the config?
Nagendra
thnks for reply,
here is configs,
One Point.
hostname AP
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 15
ip cef
interface Multilink1
bandwidth 4096
ip address 192.168.11.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip load-sharing per-packet
ppp multilink
ppp multilink fragment delay 20
ppp multilink links maximum 2
ppp multilink links minimum 1
ppp multilink interleave
ppp multilink group 1
interface FastEthernet0/0
ip address 172.18.40.1 255.255.252.0
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
interface Serial0/0
bandwidth 2048
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
no fair-queue
no dce-terminal-timing-enable
ppp multilink
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
bandwidth 2048
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
no fair-queue
ppp multilink
interface Serial0/2
no ip address
shutdown
interface Serial0/3
no ip address
shutdown
ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
end
and this is another end.
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 5
ip cef
bandwidth 4096
ip address 192.168.11.2 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ppp multilink
no ip address
shutdown
duplex auto
speed auto
ip address 172.18.36.1 255.255.252.0
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
interface Serial1/0
bandwidth 2048
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
serial restart-delay 0
no fair-queue
ppp multilink
interface Serial1/1
bandwidth 2048
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
no fair-queue
ppp multilink
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
end
thanks for your reply
it is working with same configuration. i had not wait for some time. but its taking 60 seconds to failover to antoher link til time ping are inconsistant.
so can we reduce this failover time. ???????????
awating for your reply.
