Multilink config
kpradeep_venkata
Community Member
I need a help ASAP on the below setup.... please
Can i configure multilink on 2811 router with two internet links(2MB and 1MB) both termniated on 2811 router?
Venkat.
Rick Morris
Level 11
Level 11
You can multilink ckts coming from the same isp, but that is a question for your isp.  Some providers do not allow this.  I worked with Telmex on a 4x T solution and had to run BGP for load sharing because they did not allow me to run multilink.
rich_foster
Community Member
Yes you can, providing you configure both ends for PPP multilink:
http://www.cisco.com/en/US/docs/ios/dial/configuration/guide/dia_media-ind_multi_ppp_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1054168
Basically create a multilink interface:
interface multilink 1
ip address x.x.x.x
ppp multilink
ppp multilink multiclass
And assign to your serial interfaces:
interface serial 0/0
encapsulation ppp
ppp multilink group 1
interface serial 0/1
encapsulation ppp
