Multilink E1 3725 router question?
Hi, I would like to configure a Multilink between 2 sites. My question is how many E1 can I bundle on the same Multilink. Does a router 3725 support 4 E1 on the same Multilink,the same question for a 2811 router?
regards
paolo bevilacqua
Yes, both models should have no problems with 4 links in a bundle.
hope this helps, please rate post if it does!
