Multilink Frame Relay (IOS Feature HELP!)
ryanwilhelm
Hopefully this is a relatively simple question, but I'm wondering which feature set I need to use MLFR with our Cisco 2620XM. We currently have it on a 2612XM; however, I need to set up a hot-site with the 2620XM and I can't get into the config on the 2612XM to check the IOS feature set. Does anyone know the features needed to enable Multilink Frame Relay on a 2620XM?
Thanks a bunch.
Our current IOS version is: c2600-ik9s-mz.122-28.bin
thisisshanky
Level 11
Level 11
Your feature set indicated by the flash image has an IP Plus feature set + crypto features enabled (k9). For MLFR, IP Plus is enough. You can either use 12.2T or 12.3. If you use 12.3.13, it will need 64 MB RAM and 32 MB flash on the 2620XM.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Thanks for the reply. I will give it a shot in the morning. Thanks again.
