MultilinkPPP bandwidth
titomen77
Hi folks,
I have a configuration with 2 physical WAN interfaces (each one 1024 kbps) and one Multilink group as follows:
RouterA_|====1024====|_RouterB
________|====1024====|
interface Multilink7
description ENLACE XXXXXXXXXXX
bandwidth 1024
ip address X.Y.Z.W 255.255.255.252
ip route-cache flow
ip tcp header-compression iphc-format
no ip mroute-cache
ppp multilink
ppp multilink fragment disable
ppp multilink group 7
service-policy output XXXXX
ip rtp header-compression iphc-format
interface Serial2/2
description ENLACE A
no ip address
encapsulation ppp
no ip mroute-cache
serial restart-delay 0
no fair-queue
ppp multilink
interface Serial2/6
description ENLACE B
bandwidth 1024
no ip address
encapsulation ppp
no ip mroute-cache
no fair-queue
ppp multilink
The second link was added recently, so if each interface has 1024kbps of bandwidth, should I configure the bandwidth command of the multilink group with 2048 kbps??
How would you improve this configuration?
Thanks in advance for your help!
Giuseppe Larosa
Hello Orlando,
bandwidth command is an administrative parameter.
it affects OSPF and EIGRP metric calculation and provides the reference value for some QoS commands of modular QoS like bandwidth percent.
Hope to help
Giuseppe
Joseph W. Doherty
"The second link was added recently, so if each interface has 1024kbps of bandwidth, should I configure the bandwidth command of the multilink group with 2048 kbps?? "
Either that or see if the multilink interface picks up its bandwidth from the active bundled links.
"How would you improve this configuration? "
For 2 Mbps of MLPPP bandwidth, you might consider not using the TCP and RTP header compression.
