multiple dialer interface
daysleeper
Hi to all,
i have a router 2600 with isdn interface and i have too many customers that i need to reach with remote assistance. All the customers have a isdn router in the office and i want know if there is a limit in the number of the dialer interface that i can create on the router and if exist another solution(ldap?).
Richard Burts
Carlo
Other than the general restriction on number of interfaces on a router (dependent on the number of IDBs supported in the particular version of IOS) I am not aware of any restriction on the number of dialer interfaces.
If I understand your requirements correctly, that you need to be able to connect to many customer remote sites via ISDN, then I think that dialer interfaces is the optimum solution.
Rick
Rick
Thank you Rick,you have removed a big doubt!
