multiple filters on IOS output
bellocarico
I was trying to create a filter for an IOS command.
My problem is that I need to know in a quick way the port mod/num + description
(as it was in the old CatOS command "sh port").
Now, if I do a
show interfaces | inc Giga
I get the port number but no description.
if I do a
show interfaces | inc Description
I get the description but no port number.
Is there any way to apply a "double filter" so I get 2 lines in output?
e.g.
GigabitEthernet1/32 is administratively down, line protocol is down (disabled)
Description: Link to Corporate Firewall
ankurbhasin
Level 9
Level 9
Hi Friend,
Try "show interfaces description" or "sh int brief"
Output will be something like
Router> show interfaces description
Interface Status Protocol Description
PO0/0 admin down down First POS interface
PO0/1 admin down down
Gi1/0 up up GigE to server farm
HTH, if yes please rate the post.
Ankur
ankurbhasin
Level 9
Level 9
Hi Friend,
Ankur
Thanks!
show interface description
solved the problem
(by the way it is on a 6500 running in native mode)
