Multiple Forwarded ports not showing as open.
mac989999
Hello, I'm in need of assistance .
I have a client with a cisco 1841 router with a static public ip. He has 3 dvr's he wanted to acces from the internet and we opened the ports for the dvr's ip's. The issue were having is that only the first ip that we opened shows the port opened and works ok, the other 2 ip with their ports show closed.
Heres the code:
ip nat inside source list 190 interface FastEthernet0/0.1214 overload
ip nat inside source static tcp 10.161.2.141 5445 Public IP 5445 extendable
ip nat inside source static udp 10.161.2.141 5445 Public IP 5445 extendable
ip nat inside source static tcp 10.161.2.141 5446 Public IP 5446 extendable
ip nat inside source static udp 10.161.2.141 5446 Public IP 5446 extendable
ip nat inside source static udp 10.161.2.142 37775 Public IP 37775 extendable
ip nat inside source static tcp 10.161.2.142 37776 Public IP 37776 extendable
ip nat inside source static tcp 10.161.2.140 37777 Public IP 37777 extendable
ip nat inside source static udp 10.161.2.140 37778 Public IP 37778 extendable
ip nat inside source static 10.161.2.1 66.50.152.237
tcp 10.161.2.140 37777 Public IP 37777 works ok all others dont, can anyone point me in the right direction here, this simple thing has made a long day for me, and the ISP support is not getting back to us, slow....
I apreciate any help!
-Joseph
Ps. Attached a copy of our config txt some info has bee edited for privacy concers but the commans are there.
17 Replies 17
Hello ,
Are you able telnet the pots from you router ?
lets say  from the router
telnet 10.161.2.141 5445  is this opening the socket ?
regards
Harish.
The device is a DVR, this is what I get:
mmsc-humacao#telnet 10.161.2.142 37775
Trying 10.161.2.142, 37775 ... Open
Can you post sanitized config from the router.
Regards.
Alain
It should be on my original post at the begining of the thread, does it show?
Hello Jose,
hmm.. That means those ports are actually not opened on the server itself. So it is not an issue of the router or port forwarding. The router is doing the job which is suppose to do. You may need to check with the server whether the service is really running from lan and you are able to telnet to that IP with port number..
please let me know if you have any further queries
Harish.
Please rate all helpful posts!
correction, I made error, that IP that I showed, the DVR was turned OFF power wise, this one Is on,
But it shows open on router but not outside on the internet.
telnet uses TCP and in your static NAT you are using UDP:
Regards.
Alain
Tried with the TCP port:
mmsc-humacao#telnet 10.161.2.142 37776
Trying 10.161.2.142, 37776 ...
% Connection refused by remote host
any suggestions?
Hello Jose,
this shows that the server is either not listening to the port or it is refusing your connection
regards
Harish.
As I metioned at the begining this is for a DVR-Digital Video Recorder, aka security cameras.
Theres no firewalls setup, no servers, just internet-static ip,the 1841 router, a poe switch for powering accespoints and thas all, its a basic setup, One works ok, I can see the other one internally, but if one goes to a port checking tool on the net, the other 2 dvr pors show as closed, on my first post you can observe that the code was copied identical as for the one thats working, misus the ip and port info.
Any suggestions?
Could you check the server's TCP/IP settings if correct? Is it able to ping the 1841?
Is there any firewall in between?
Yes I can Ping the 1841, internally and remotely from the internet using telnet.
No firewall, servers, and the isp doesnt block ports on theri end all we have is a static ip, all I can tell the issues lies within the router config, something is missing, what I dont know.
This means your host is listening on TCP port 37775 so change your NAT statement for this port to use TCP instead of UDP and try again from outside. Is it still failing ?
Regards.
Alain
Just to check switched as you suggest, same issue, only 10.161.2.140 tcp  377777 shows open from the internet , code was copied exact for the other  2 dvrs but they dont show as open.
Thers no servers, firewals, etc... just  static ip, the 1841, a switch with poe and 4 A/P.
The device is a DVR, Digital Video Recorder, this particular model uses 2 separate ports a TCP and UDP, 37775UDP and 37776TCP for external video viewing I need the TCP 37776 to work, neither one works, when one verifies ports on a port checking tool it shows  that they are closed.
Suggestions...
