Multiple GRE on the same gear (6500 or ASR)
James Lasky
Dear all,
the bug CSCdy72539 states that on Cisco 6500 with SUP720 if are created multiple GRE interfaces using the same source address traffic is switched in CPU instead of hardware, it seems the issue is solved with SUP2T.
The question: can ASR1001X suffer of the same issue ?
I’m not able to find any info on the web.
Can anyone help ?
Cheers
Joseph W. Doherty
As far as I know, that's not an issue with the ASR 1Ks.
Where can I find a Cisco statement about that ?
Cheers
Don't know - might not exist as/if it's a non-issue on ASRs.
BTW, specifically, I have an production ASR1001-X running multiple tunnels, using same source interface, w/o any issues.
