multiple IPs via DHCP
bardh1077
I have a 876 router that works great with RFC1483 and one IP. I get the IP via DHCP.
This is (some of) my configuration:
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 8/35
bridge-group 1
interface BVI1
mac-address 0012.7f8e.8c14
ip address dhcp
ip nat outside
ip virtual-reassembly
My ISP has given me 4 more IP's to use, but I can only attain the first one via DHCP. If i had static IP's I would use 'ip address x.x.x.x 255.255.255.252 secondary' - but this isn't possible on DHCP on the same interface.
Do any of you guys have suggestions on how I can bind my 4 other IPs to the router?
I like the NAT-config, and would like to use the other IP's with NAT as well.
bardh
7 Replies 7
cadet alain
You don't need to bind any of these IPs to interfaces to use them with NAT.
kyukim
When your ISP assigns 4 static public addresses to you, you use one address for your router interface and user other 3 IP address for static NAT creation for your servers.
For examples, my ISP gave 4 public IP of 11.1.1.1~11.1.1.4 and my router got 11.1.1.1 from ISP dhcp server.
Then, I will use 11.1.1.2 for my exchange server and 11.1.1.3 for my web server and 11.1.1.4 for FTP server and create static NAT for these 3 addresses so outside world will get to my servers.
Hope this helps.
KK.
Hi!
Thanks for your reply.
I see what you're saying - but I want all the IPs to be bound to the router. Is that not possible?
How would I go on to create static NAT on the four other IPs?
bardh
bardh1077 wrote:
Hi!
bardh
Bardh
Not sure what you mean by binding. As long as the IPs are routed to you by the ISP which they will be as they have been allocated to you -
internal server = 192.168.5.10
spare public IP = 1.1.1.10
ip nat inside source static 192.168.5.10 1.1.1.10
if you want to use the same public IP for multiple internal servers you can use ports eg.
ip nat inside source static tcp 192.168.5.10 80 1.1.1.10 80
ip nat inside source static tcp 192.168.5.10 443 1.1.1.10 443
etc..
Jon
Hi Jon
Sorry if I am unclear.
What I mean is, I can't use the IP if it's not leased by DHCP.
I have a pool of 5 IP's, but I can only use 1 at the time on the router (the one "bound" by dhcp).
So the example you gave me doesn't work, because i only have the primary IP leased.
Is there a way to make more than one DHCP request over the same WAN-interface, and in that way making more IPs "usable"?
(Like creating ethernet alias in linux - eth0 for the first ip, eth0:0 for second ip, and so on)
bardh
Router can't have two ip addresses in same subnet as router is to route pkt for different subnet.
So, it is not possible.
KK.
bardh1077 wrote:
Hi Jon
bardh
Bardh
Ahhh, i understand. Are those other addresses assigned to your company or are they free to useby other companies ?
You could still use just the one address you get via DHCP by using the port example i gave before.
Jon
