Multiple multilinks on STM on Cisco 7507 router
I have Cisco 7507 router on which previously only one multilink is configured and it is applied to four stm interfaces.Now i want to configure two multilinks and want to apply on bundle of two stm interfaces each.But when I created two multilinks and applied on bundle of two interfaces ,it is observed that only one multilink is showing up at a time. but i want both multilinks UP .
My STM interface P/N is PA-MC-STM-1SMI
Pls give me the soln
10 Replies 10
bjornarsb
Level 4
Level 4
to help you we need some more infomation on your current configuration.
BR,
bjornarsb
Hi bjornarsb
Kindly let me know what information you need.
Vaishali
Is it channelized STM1 you are using ?
BR,
Bjornarsb
Attaching sample conf
controller SONET 1/1/0
framing sdh
au-4 1 tug-3 1
tug-2 1 e1 1 unframed
tug-2 1 e1 1 description UNUSED
tug-2 1 e1 2 unframed
tug-2 1 e1 2 description UNUSED
tug-2 1 e1 3 unframed
tug-2 1 e1 3 description UNUSED
tug-2 2 e1 1 unframed
tug-2 2 e1 1 description UNUSED
tug-2 2 e1 2 unframed
tug-2 2 e1 2 description UNUSED
tug-2 2 e1 3 unframed
tug-2 2 e1 3 description UNUSED ---------- SO ON
au-4 1 tug-3 2
tug-2 1 e1 1 description **E1 TO XXXX**
au-4 1 tug-3 3
tug-2 2 e1 3 description UNUSED ----------- SO ON
interface Serial1/1/0.1/1/3/1:0
description **TO xxxx**
no ip address
encapsulation ppp
no fair-queue
ppp multilink
ppp multilink group 1
interface Serial1/1/0.1/2/6/1:0
no ip address
encapsulation ppp
no fair-queue
ppp multilink
interface Serial1/1/0.1/2/6/2:0
description **xxxx**
no ip address
encapsulation ppp
no fair-queue
ppp multilink
interface Serial1/1/0.1/2/6/3:0
no ip address
encapsulation ppp
no fair-queue
ppp multilink
interface Multilink1
description ** To xxxx **
ip address (IP ADDRESS OF MULTILINK)
ppp multilink
Now i want to break this multilink (4 bundles)
with two multilink(2 bundles)e.g. multilink 1(2 bundles) and multilink 2(2 bundles)
But if i do second multilink(multilink 2) it remains down(shows protocol down for multilink interface and physical interfaces also shows protocol down which are bundeled in that multilink)
Pls suggest
Vaishali
Check that your links correspond to the right
interface on the other end. However this should be straigth forward.
Issue a show ppp multilink on both sides.
Else you could try to debug.
BR,
Bjornarsb
We have confirmed links corresponding to the other end before configuring new multilink.
But still we are facing the problem.
Vaishali
Can we bundle two links one on channel (au-4 1 tug-3 1) and other on other channel (au-4 1 tug-3 2)
And do we need to enable distributed CEF?
Vaishali
Yes you can do as you say.
And distributed CEF has nothing to to about getting your interfaces up up.
Have you tried debub ppp multilink ?
BR,
Bjornarsb
BR,
Bjornarsb
Hi Vaishali,
It's far from February, but have you already solved this problem?
If not, you may try commands 'ppp multilink endpoint none' or 'ppp multilink endpoint ip ' under the serial interfaces to not conflict endpoint discriminators among different multilink bundles.
Sincerely,
Gustavo Moreira
