Multiple Nat Conf
dreams_as_money
Hi everyone
I hope U are doing well
I have faced configuration of multiple nat/pat  problem
Point is when I paste into router another  nat pool or  nat with route-map or just static  nat  they doesn't work I mean only one of them works
so could someone tell  me whats  wrong  and why it didn't work
So, I have several connection
hardware cisco 2811 latest ios 15.1
1. internet
2. Local host that  must be translated into global local ip addresses be routed
3. vpn  local hosts that must be translated into local global addres
here is conf. example
ip nat inside source route-map SDM_RMAP_1 interface FastEthernet0/0.2 overload
ip nat inside source route-map SDM_RMAP_2 interface FastEthernet0/1.4 overload
New nat conf...
ip nat pool hk 172.********* 172.********** netmask 255.255.255.128
ip nat inside source list 108 pool hk overload
ip nat pool ap 172.********* 172.********** netmask 255.255.255.128
ip nat inside source list 107 pool ap overload
ip nat inside source static tcp 192.168.0.65 22 *****(Wan) 2220 extendable
ip nat inside source static tcp 192.168.0.65 80 ******(Wan) 4430 extendable
ip nat inside source static tcp 192.168.0.65 443 *****(Wan) 4431 extendable
access-list 106 permit ip host 192.168.0.193 any
access-list 107 per ip host  192.168.0.66 any
access-list 108 per ip host 192.168.0.66 any
route-map SDM_RMAP_1 permit 1
match ip address 100
route-map SDM_RMAP_2 permit 1
match ip address 106
Marwan ALshawi
when you use NATing over multiple physical interface you need to use the command match interface ( exit interface ) with the route-map
see the bellow doc
https://supportforums.cisco.com/docs/DOC-8313
hope this help
if helpful Rate
I  tried it but it didn't work
could U clarify?
route-map ap permit 1
match ip address 107
match interface FastEthernet0/1.5
access-list 107 permit ip 192.168.0.0 0.0.255.255 any
ip nat inside source route-map ap interface FastEthernet0/1.5 overload
interface FastEthernet0/1.5   (Local wan)
encapsulation dot1Q 129
ip address *****************  255.255.255.128
no ip redirects
ip nat inside
ip virtual-reassembly in
interface FastEthernet0/0.4  wan
description Ap
encapsulation dot1Q 99
ip address**************  255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
no cdp enable
Have you updated the route map of int 0/0.4 ?
Hey Man
Let me clarify
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
duplex auto
speed auto
no mop enabled
interface FastEthernet0/0.1 (wan  for fa 0/1.6)
description Ho
encapsulation dot1Q 31
ip address ********  255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no cdp enable
interface FastEthernet0/0.2 (internet)
description m$ETH-LAN$
encapsulation dot1Q 143
ip address *************  255.255.255.240
ip access-group udp in
no ip redirects
no ip unreachables
no ip proxy-arp
ip verify unicast reverse-path
ip nbar protocol-discovery
ip flow ingress
ip flow egress
ip nat outside
no cdp enable
crypto map   ****
interface FastEthernet0/0.3 (Wan-another service)
description MC
encapsulation dot1Q 100
ip address *******  255.255.255.224
ip access-group udp-mc in
no ip redirects
no ip unreachables
no ip proxy-arp
no cdp enable
crypto map ********
interface FastEthernet0/0.4 (Wan  for fa 0/1.5)
description Ap
ip address *************  255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no cdp enable
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1.1 (Local for Vpn traffic)
ip address ***************  255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
interface FastEthernet0/1.2   (Local lan)
encapsulation dot1Q 8
ip address ************  255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
interface FastEthernet0/1.3  (Local for  fast 0/0.3)
description MC-Lan
encapsulation dot1Q 300
ip address *******************  255.255.255.224
no cdp enable
interface FastEthernet0/1.4  (Local  for vpn traffic)
description PAy local
encapsulation dot1Q 304
ip address***************  255.255.255.248
ip nat inside
no cdp enable
interface FastEthernet0/1.5 Local  for  fast 0/0.4 I want translate this  local  traffic to my local addres  192.168.0.0/24
description ap
ip address ***************  255.255.255.128
interface FastEthernet0/1.6  (Local for fast 0/0.1) I want translate this  local  traffic to my local addres  192.168.0.0/24
desc Ho
encapsulation dot1Q 127
ip address *********   255.255.255.128
ip nat inside source route-map Ho interface FastEthernet0/1.6 overload
ip nat inside source static tcp 192.168.0.65 22 ************  2220 extendable
ip nat inside source static tcp 192.168.0.65 80 ****************** 4430 extendable
ip nat inside source static tcp 192.168.0.65 443 ************** 4431 extendable
ip acce ex  100 per hosts *****
ip acce  ex 106  per hosts   *********
ip acce  ex  107 per **********
ip acce ex 108 per *********
match interface FastEthernet0/0.2
match interface FastEthernet0/1.4
route-map Ho per 1
match ip add 107
match int fa 0/1.6
route-map ap per 1
match ip add 108
match int fa 0/1.5
