Multiple NAT statements processing
Hi all,
I tried to simulated NAT loadbalancing with Multiple ISPs.I configured it as per the doc.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080950834.shtml
I ve got few queries regarding this.
1)ip nat inside source route-map MAP1 interface FastEthernet0/1 overload
   ip nat inside source route-map MAP2 interface FastEthernet1/0 overload
I configured two NAT statements one per ISP. how will this statement affect the processing.
How does the router choose the "ip nat inside source" statement. My question is if we have multiple "ip nat" statements
how will they be processed.
Selection of NAT statements occurs only after the routing decision. Hence when a packet arrives on the NAT inside interfaces, it checks the destination and selects the egress interface and depending upon the egress interface it selects the NAT translation entry.
Since you are using dual ISP with overload on both exit points. Depending upon which exit is selected based on routing pattern, its configured NAT statement will be processed. Hence it is needed to make sure that your route-map also matches the exit interfaces as below
route-map MAP1
match access-group <>
match interface fa0/1
Check the nat order of operation.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080133ddd.shtml
Please rate this post if you find it helpful.
Rgds,
Sebastian Fernandez
So after routing decision, which decides the exit interface the NAT statement is selected.In the case where I have mentioned the interfaces are
overloaded and hence the appropriate interface gets selected
What happens when there is pool. How is the NAT statement selected? Does NAT check for the pool with the same subnet as the exit interface?
Thanks.
Incase you are NATting over multiple pools and no route-map (match interface) specified, it translates on the first statement in configuration. Hence it is a recommended design to use match interface when configuring NAT for different ISPs. Moreover in most ISP design, incoming traffic sourced from different ISP address space is not allowed and also leads in black holing and asymetric routing from ISP.
Rgds,
Sebastian Fernandez
