Multiple public IP addresses on 877W
pentester1964
Hello all,
I wonder if someone could help me on a little matter I have. I would like to configure an 877w I just bought. It's connecting to a UK ADSL2+ link.
I'm a penetration tester and I want to put the Cisco router in front of my existing firewall which has an IPS on it, so that it doesn't get in the way of port scans and vulnerability scans. My ISP has issued me with 14 usable addresses a/240 subnet and basically I want to be able to use the route with just the public IP addresses. I have configured Cisco routers before, but never with this type of configuration. It's always been single public IP address  NAT'd through to one or two internal LAN's.
It will be nice if I could assign the wireless and fast ethernet ports to the same VLAN using the public addresses. I don't want to use DHCP I'm quite happy statically assigning IP addresses to the computers wireless and LAN interfaces. I am reasonably certain this is possible because not sure how to do it and a little busy at the moment carrying out penetration tests.
If someone out there could provide me with a basic script I can apply from the cli, I will gladly donate £50 today named charity.
Many thanks in advance.
7 Replies 7
cadet alain
to have interfaces both in the same subnet on a router you must either use VRF lite or transparent bridging.
It wont work with just one RIB.
Regards.
Alain
I would happily settle for using just th fast ethernet ports and I could configure static NAT to the wireless.
the router won't let you configure 2 interfaces on the same router both in the same subnet unless you do what I proposed above.
Regards.
Alain.
In that case would it be something like this below?
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/30
encapsulation aal5mux
dsl operating-mode auto
bridge-group 1
interface Vlan1
no ip address
bridge-group 1
bridge 1 protocol ieee
interface ATM0
no ip address
pvc 0/38
bridge-group 1
interface Vlan1
no ip address
bridge-group 1
for transparent bridging yes
Regards.
Alain
OK for some reason it doesn't work.
anyone any ideas why that might be? Here's the config.
version 15.1
no service pad
hostname router
boot-start-marker
boot-end-marker
enable secret 5 noyoucantseeit
enable password noyoucantseeit
no aaa new-model
dot11 syslog
ip source-route
no ip routing
no ip cef
no ipv6 cef
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
bridge-group 1
pvc 0/38
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
no ip address
no ip route-cache
bridge-group 1
interface Dialer0
ip address negotiated
ip virtual-reassembly in
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname user@myisp.com
ppp chap password 0 noyoucantseeit
no cdp enable
bridge-group 1
ip forward-protocol nd
no ip http server
no ip http secure-server
logging esm config
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input all
end
if you get dhcp address from provider then you need to do routing, it won't work with bridging. maybe you could try IRB and leave vlan 1 interface as bridged and still route on the dialer interface.
Regards.
Alain.
