mwam module 6500
Hi all
I have to configure a process in a mwam module the session time out b4i set the local username
Now I am unable to log back into the process it's asking me for username
Is there any way to clear the process config and rest the process alone with out restring the module
Thx all
its solved
#session slot 9 processor 1
The default escape character is Ctrl-^, then x.
You can also type 'exit' at the remote prompt to end the session
Trying 127.0.0.91 ... Open
SVCMWAM Image version 2.1(3.0)
Thu May 25 17:42:14 PDT 2006
Copyright (c) 2002-2003, 2004 by cisco Systems, Inc.
All rights reserved.
Kernel 2.4.26.komodo on an i686
login: root
Password:cisco
root@mwam-9#?
clear            - clear log files
logout           - logout of the shell
passwd           - set the password for the current user
reload           - reload an mwam processor complex
restore          - restore the previous IOS image after an IOS upgrade
show             - show system parameters
normal-ios       - boot mwam processor complex in normal mode
recover-ios      - boot mwam processor complex in recovery mode
boot-mode        - set mwam processors to boot supervisor or local configs
?                - display this help
help             - display this help
root@mwam-9#reload processor 4
