my cisco router not working
M02@rt37
Hello @jppradeepkumar13,
You have an adpater serial/USB ?
You are using Cisco console cable !
Best regards
yha i am use usb console port
Ok @jppradeepkumar13
Confirm that CONSOLE speed baud is conform
Confirm that you have installed the driver of your USB/serial adapter and it is recongnized by your OS
Best regards
Mark Elsen
 - Looks like a baudrate mismatch ; tap the space bar when the router boots , check if that can help ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
