No I dont see the way to increase it. Please find below details:
Nexus 7700 F3-Series 12-Port 100 Gigabit Ethernet Module
- Layer 2 / Layer 3
- 12 x 100 Gbps (CPAK)
- 192 x wire-rate 100 Gigabit Ethernet ports are supported in a Nexus 7718 chassis
- 1.8 billion packets per second layer 2 and layer 3 IPv4 and IPv6 forwarding
- 1.2 Tbps of data throughput (2.4 Tbps full-duplex)
- 7710 and 7718 chassis
- Supervisor Engine 2E
- Fabric-2 Module (7010 and 7018 chassis)
- 4 ingress and 8 egress queues per port
- Jumbo Frame Support
- 64K MAC addresses
- 4096 VLANs per VDC
- 64K IPv4 routes
- 32K IPv6 routes
- Switch on Chip (SoC) ASIC
- N77-F312CK-26
Nexus 7700 F3-Series 24-Port 40 Gigabit Ethernet Module
- Layer 2 / Layer 3
- 24 x 40 Gbps (QSFP+)
- 384 x wire-rate 40 Gigabit Ethernet ports in a Nexus 7718 chassis
- 1.44 billion packets per second layer 2 and layer 3 IPv4 and IPv6 forwarding
- 960 Gbps data throughput (1.92 Tbps full-duplex)
- 64K MAC addresses
- 64K IPv4 routes
- 32K IPv6 routes
- N77-F324FQ-25
Nexus 7700 F3-Series 48-Port Fiber 1 and 10 Gigabit Ethernet Module
- Layer 2 / Layer 3
- 48 x 1/10 Gbps (SFP and SFP+)
- 768 x wire-rate 10 Gigabit Ethernet ports in a single Nexus 7718 chassis
- 720 million packets per second layer 2 and layer 3 IPv4 and IPv6 forwarding
- 480 Gbps data throughput (960 Gbps full-duplex)
- 7706, 7710 and 7718 chassis
- 64K MAC addresses
- 64K IPv4 routes
- 32K IPv6 routes
- N77-F348XP-23
Nexus 7700 F2-Series Enhanced 48-Port Fiber 1 and 10 Gigabit Ethernet Module
- Layer 2 / Layer 3
- 4 ingress and 4 egress queues per port
- 16K MAC addresses
- 32K IPv4 routes
- 16K IPv6 routes
- N77-F248XP-23E
- NX-OS 6.2.2+
Nexus 7000 F3-Series 6-Port 100 Gigabit Ethernet Module
- Layer 2 / Layer 3
- 6 x 100 Gbps (CPAK)
- 96 x wire-rate 100 Gigabit Ethernet ports in a single Nexus 7018 chassis
- 900 million packets per second layer 2 and layer 3 IPv4 and IPv6 forwarding
- 600 Gbps data throughput (1.2 Tbps full-duplex)
- 7004, 7009, 7010 and 7018 chassis
- Supervisor Engine 1, 2 and 2E
- Fabric-1 Module (7010 and 7018 chassis), Fabric-2 Module (7009, 7010, 7018 chassis)
- 64K MAC addresses
- 64K IPv4 routes
- 32K IPv6 routes
- N7K-F306CK-25
Nexus 7000 F3-Series 12-Port 40 Gigabit Ethernet Module
- Layer 2 / Layer 3
- 12 x 40 Gbps (QSFP+)
- 192 x wire-rate 40 Gigabit Ethernet ports in a single Nexus 7018 chassis
- 64K MAC addresses
- 64K IPv4 routes
- 32K IPv6 routes
- N7K-F312FQ-25
Nexus 7000 F2-Series Enhanced 48-Port Fiber 1 and 10 Gigabit Ethernet Module
- Layer 2 / Layer 3
- 768 x wire-rate 10 Gigabit Ethernet ports in a single Nexus 7018 chassis
- 16K MAC addresses
- 32K IPv4 routes
- 16K IPv6 routes
- N7K-F248XP-25E
- NX-OS 6.1.2+
Nexus 7000 F2-Series Enhanced 48-Port 1 and 10GBASE-T Ethernet Copper Module
- Layer 2 / Layer 3
- 48 x 1/10 Gbps (RJ-45)
- 768 x wire-rate 10GBase-T Ethernet ports in a single Nexus 7018 chassis
- 16K MAC addresses
- 32K IPv4 routes
- 16K IPv6 routes
- N7K-F248XT-25E
- NX-OS 6.1.2+
Nexus 7000 F2-Series 48-Port 1 and 10 Gigabit Ethernet Module
- Layer 2 / Layer 3
- 16K MAC addresses
- 32K IPv4 routes
- 16K IPv6 routes
- N7K-F248XP-25
- NX-OS 6.0+
Nexus 7000 F1-Series 32-Port 1 and 10 Gigabit Ethernet Module
- Layer 2
- 32 x 1/10 Gbps (SFP and SFP+)
- 512 x wire-rate 10 Gigabit Ethernet ports in a single Nexus 7018 chassis
- 480 million packets per second layer 2 forwarding
- 320 Gbps data throughput (640 Gbps full-duplex)
- 7009, 7010 and 7018 chassis
- 256K MAC addresses
- 16K VLANs per module
- N7K-F132XP-15
- NX-OS 5.1.1
Nexus 7000 M2-Series 24-Port 10 Gigabit Ethernet Module with XL Option
- Layer 2 / Layer 3
- 24 x 10 Gbps (SFP+)
- 384 x wire-rate 10 Gigabit Ethernet ports in a single Nexus 7018 chassis
- 120 million packets per second layer 2 and layer 3 IPv4 forwarding and 60 mpps IPv6
- 550 Gbps data throughput (1.1 Tbps full-duplex)
- 8 ingress and 8 egress queues per port
- 128K MAC addresses
- 1M IPv4 routes
- 350K IPv6 routes
- N7K-M224XP-23L
- NX-OS 6.1+
Nexus 7000 M2-Series 6-Port 40 Gigabit Ethernet Module with XL Option
- Layer 2 / Layer 3
- 6 x 40 Gbps (QSFP+)
- 96 x wire-rate 40 Gigabit Ethernet and 10 Gbps ports in a Nexus 7018 chassis
- 1M IPv4 routes
- 350K IPv6 routes
- N7K-M206FQ-23L
- NX-OS 6.1+
Nexus 7000 M2-Series 2-Port 100 Gigabit Ethernet Module with XL Option
- Layer 2 / Layer 3
- 2 x 100 Gbps (CFP)
- 32 x wire-rate 100 Gigabit Ethernet ports in a single Nexus 7018 chassis
- 550 Gbps of data throughput (1.1 Tbps full-duplex)
- 1M IPv4 routes
- 350K IPv6 routes
- N7K-M202CF-22L
- NX-OS 6.1+
Nexus 7000 M1-Series 8-Port 10 Gigabit Ethernet Module with XL Option
- Layer 2 / Layer 3
- 8 x 10 Gbps (X2)
- 128 x wire-rate 10 Gigabit Ethernet ports in a single Nexus 7018 chassis
- 80 Gbps of data throughput (160 Gbps full-duplex)
- 1M IPv4 routes
- 350K IPv6 routes
- N7K-M108X2-12L
- NX-OS 5.0+
Nexus 7000 M1-Series 32-Port 10 Gigabit Ethernet Module with XL Option
- Layer 2 / Layer 3
- 32 x 10 Gbps (SFP+)
- 512 x 10 Gigabit Ethernet ports in a single Nexus 7018 chassis
- 60 million packets per second layer 2 and layer 3 IPv4 forwarding and 30 mpps IPv6
- 1M IPv4 routes
- 350K IPv6 routes
- 4:1 oversubscription
- N7K-M132XP-12L
- NX-OS 5.1+
Nexus 7000 M1-Series 48-Port Gigabit Ethernet Modules with XL Option
- Layer 2 / Layer 3
- 48 x 1 Gbps (SFP/RJ45)
- 768 x Gigabit Ethernet (SFP) or 10/100/1000 (RJ45) ports in Nexus 7018 chassis
- 46 Gbps of data throughput (92 Gbps full-duplex)
- 2 ingress and 4 egress queues per port
- 1M IPv4 routes
- 350K IPv6 routes
- Some oversubscription
- N7K-M148GS-11L
- NX-OS 5.0 (SFP) / 5.1+ (RJ45)
- Layer 2 / Layer 3
- 128K FIB routes
- N7K-M132XP-12
- NX-OS 4.0+
- Layer 2 / Layer 3
- 768 x 10/100/1000 RJ45 or Gigabit Ethernet (SFP) ports in Nexus 7018 chassis
- 128K FIB routes
- N7K-M148GT-11
- NX-OS 4.1+ (SFP) / 4.0+ (RJ45)
