NAT and ACL configuration
snoto1974
It's been a while since the last time I worked on a router config. I'm having issues giving the inside network access to the internet via the GigabitEthernet0/0/0 interface. In the end I would like to have a redundant route to go out the GigabitEthernet0/0/1 interface but I will work on that once get the traffic flowing out of the primary network. Below is the start of my config. Can someone tell me what I am missing? Is my NAT or ACL wrong? Thanks in advanced.
Current configuration : 1745 bytes
! Last configuration change at 17:17:30 UTC Tue Apr 25 2017
version 15.5
no platform punt-keepalive disable-kernel-core
hostname Router
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no logging buffered
enable password <Removed>
no aaa new-model!
subscriber templating
license udi pid ISR4331/K9 sn FDO20450SH5
username <Removed> privilege 15 password <Removed>
redundancy
mode none
vlan internal allocation policy ascending
interface GigabitEthernet0/0/0
description Primary Network
ip address <IP Removed>
ip nat outside
ip nat allow-static-host
negotiation auto
interface GigabitEthernet0/0/1
description Secondary Network
ip address <IP removed>
ip nat outside
negotiation auto
interface GigabitEthernet0/0/2
description To ASA Port 0
ip address 192.168.20.1 255.255.255.0
ip nat inside
ip access-group 100 in
ip access-group 100 out
negotiation auto
vrf forwarding Mgmt-intf
no ip address
negotiation auto
interface Vlan1
no ip address
shutdown
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 204.148.103.197
ip route 0.0.0.0 0.0.0.0 70.107.239.1 10
access-list 100 permit ip any any
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password <Removed>
login
end
16 Replies 16
Below is the output of the show ip route command. The primary line is currently disconnected.
Gateway of last resort is 70.107.239.1 to network 0.0.0.0
S* 0.0.0.0/0 [10/0] via 70.107.239.1
70.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 70.107.239.0/24 is directly connected, GigabitEthernet0/0/1
L 70.107.239.211/32 is directly connected, GigabitEthernet0/0/1
Hi singh,
This post is very helpful. Thanks for sharing your knowledge.
