NAT and SSH Management on the outside interface
bob.bartlett
I have a 2811 router running advanced ip services and I can't connect to the outside interface using SSH or TELNET. I am NAT'ing all my outbound traffic at that interface if i turn off NAT i can connect. Any ideas?
Edison Ortiz
Can we see the config ?
You should only include the internal network in the NAT ACL, not the outside interface.
Thanks that was the key I needed I just couldn't see the trees from the forest and went back and saw that my partner had done and any any on the NAT ACL.
