nat balacing
stephtchoko
Level 7
Level 7
Please, is it possible to configure nat to translate address on two differents class on same router ? How ?
for example:
RTA
eth0/0 (WAN)
194.202.232.1
195.202.232.1
eth0/1
10.1.1.1
We want a specfic sunet of network 10.0.0.0 to be transalte on 194.202.232.1
and a second to be translate on 195.202.232.1.
Best regards
spremkumar
Level 11
Level 11
hi
though i havent done something yet on this line would suggest to try out something which may be a pathbreaker ..
ip nat pool pool-1 194.202.232.1 194.202.232.1 prefix-length 30
ip nat pool pool-2 195.202.232.1 195.202.232.1 prefix-length 30
ip nat inside source route-map MAP-101 pool pool-1
ip nat inside source route-map MAP-102 pool pool-2
interface ethernet0
ip address 194.202.232.1
ip address 195.202.232.1
ip nat outside
interface ethernet1
ip address 10.1.1.1
ip nat inside
access-list 101 permit ip 10.x.x.x y.y.y.y any
access-list 102 permit ip 10.a.a.a y.y.y.y any
route-map MAP-101 permit 10
match ip address 101
route-map MAP-102 permit 10
match ip address 102
i hvent mentioned the subnet mask info since you didnt post any info about that.
so i left it blank.
in the config just break the subnets into 2 based on the PAT ur gonna do with the public ip.
configure the ACLS matching them accordingly then bind it in the route maps.
After this just configure ur pool i assume u r having /30 block in ur outside interface.'
create 2 pools as i hve mentioned out ..
bind the route map in adjacent with the nat inside command .hope that may help u out in achieving ur requirement.
regds
