NAT - config Review
ronald.ramzy
I need to allow only http traffic on the natted IP ( via acl ) and block all connection initiated from outside to inside.
Only allow connection initiated from inside to outside
M i missing anything,
********Configuration ******************
ip subnet-zero
ip domain lookup source-interface FastEthernet0/0
ip name-server 4.4.4.4
description Connected to ISP
ip address 10.10.10.66 255.255.255.224
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
description Connection to LAN-Switch
ip address 192.168.1.100 255.255.255.0
ip accounting output-packets
ip nat inside
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.10.65
ip route 172.20.16.0 255.255.255.0 192.168.1.1
no ip http server
no ip http secure-server
ip nat inside source static 192.168.1.101 10.10.10.68
access-list 50 permit 192.168.1.101
access-list 50 deny any
Jon Marshall
Ronald
Where is acl 50 being used ?.
Can you just clarify, you want
1) all internal clients to be allowed to initiate connections to the Internet
AND
2) you want to allow internet access to 10.10.10.68 on port 80
If this isn't what you want can you be more specific.
Jon
ACL 50 was earlier used with IP NAT Pool which i removed with static NAT.
(1) all web traffic from inside goes to ISA server. so I want Microsoft ISA Server to initiate traffic from inside to Outside
(2) No traffic should initiate from Internet to Microsoft ISA Server
Since there is no firewall, I want to secure the connection as much as possible
Ronald,
If you're wanting to allow traffic from the outside in, you can do one-to-one nat (like you are) and then block with the acl:
ip access-list ext OUTSIDE
permit tcp any host 10.10.10.68 eq 80
permit tcp any any established
deny ip any any
int fa0/0
ip access-group OUTSIDE in
HTH,
John
HTH, John *** Please rate all useful posts ***
