NAT configuration for servers which act as both initiator & Responder
Aaida
I am having below scenario.
1. I have one internal server a.a.a.a which having NATed IP b.b.b.b
2. The internal server is connecting to outside server c.c.c.c over ipsec VPN.
3. The outside server c.c.c.c will also initiate traffic to inside servers NAT IP b.b.b.b. which means both side initiation is there. Please note that i am not talking about reverse traffic of same session.
Now my question is whether i need to put two NAT rules, one to translate for inbound traffic and other to translate for outbound traffic. is that required. or one NAT rule will serve the purpose?
20 Replies 20
If b.b.b.b is the natted IP for a.a.a.a this means that server c.c.c.c can call b.b.b.b and talk to a.a.a.a.a directly. I dont see the need for two NAT.
Sheraz.Salim
@Flavio Miranda said there is no need for two NAT rules.
but here are my thoughts you will need Outbound NAT, This rule is needed to translate the source IP address of the internal server (a.a.a.a) to the NAT IP address (b.b.b.b) when it initiates traffic to the outside server (c.c.c.c) over the IPsec VPN. This ensures that the outside server sees the traffic coming from the NAT IP. YOu will also need Inbound NAT as the outside server (c.c.c.c) initiates traffic to the internal server's NAT IP (b.b.b.b), you need an inbound NAT rule to translate the destination IP address from the NATed IP (b.b.b.b) to the internal server's IP (a.a.a.a). This allows the internal server to receive traffic initiated by the outside server.
By configuring both outbound and inbound NAT rules, you ensure that bidirectional communication is established correctly between the internal server and the outside server over the IPsec VPN.
please do not forget to rate.
@Sheraz.Salim this is what I was looking for. So two nat rules are required one to translate inbound packet and other translate outbound packet as both side individual initiation are there.
If b.b.b.b is the NATed IP address for a.a.a.a and this IP (b.b.b.b) can reach IP c.c.c.c, why c.c.c.c can not iniciate traffic to b.b.b.b directly?
We are not calling an internal IP address a.a.a.a here from outside, we are calling an NATed IP address b.b.b.b which, theorically should be "visible" by c.c.c.c.
@Flavio Miranda
Apologies for any confusion caused. You are correct that if the NATed IP address b.b.b.b is reachable by the outside server c.c.c.c, it should be possible for c.c.c.c to initiate traffic directly to b.b.b.b.
In the scenario, where outbound NAT translates the source IP address of the internal server (a.a.a.a) to the NAT IP address (b.b.b.b) and inbound NAT translates the destination IP address from the NATed IP (b.b.b.b) to the internal server's IP (a.a.a.a), bidirectional communication is established over the IPsec VPN.
However, if there is a need for c.c.c.c to directly initiate traffic to b.b.b.b without going through the IPsec VPN, additional network configurations may be required. These configurations could involve routing, firewall rules, or other etc to allow direct communication between c.c.c.c and b.b.b.b.
No appologies needed  @Sheraz.Salim  I am also trying to understand.
Thank you so much everyone.  I will try with one nat rule. Most probably this should work according to above conversation.
If I undertood right, it should. But, nothing better then give it a try.
Try it mate. it will clear it out.
You have Router or FW?
Router sir
from My view why you want to NATing from a.a.a.a to b.b.b.b, VPN is used to connect privates network over public.
NATing to interface that you config crypto under is not work, if you want c.c.c.c to connect to b.b.b.b only and not to subnet a.a.a.a then you need config LO with b.b.b.b and do route-map and ip nat enable in LO, that long story.
can you more elaborate why you need it ?
@MHM Cisco World Its the ASR-1000 series Router.
I see his label but I need to be sure
