nat doesn't work on cisco 871
ssemenenko
Hello, buddies.
I'm trying to configure cisco 871 for Internet access through pppoe.
Here is my config:
Current configuration : 1996 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 $1$L/Qh$pAh6sCNUtAtG7tnANlFZy.
no aaa new-model
dot11 syslog
ip source-route
ip dhcp excluded-address 192.168.1.1
ip dhcp pool pooldhcp
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
lease 0 2
ip cef
no ipv6 cef
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
archive
log config
hidekeys
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
no ip address
ip nat outside
ip nat enable
ip virtual-reassembly
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface Vlan1
ip nat inside
interface Dialer0
ip address negotiated
ip mtu 1492
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp chap refuse
ppp ms-chap refuse
ppp ms-chap-v2 refuse
ppp pap sent-username <CUTTED> password 0 <CUTTED>
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 192.168.1.0 255.255.255.0 Dialer0
no ip http server
no ip http secure-server
ip nat pool pool1 192.168.1.1 192.168.1.254 netmask 255.255.255.0 add-route
ip nat inside source list 1 interface Dialer0 overload
ip access-list extended TerminalAccess
permit tcp host 192.168.1.2 any eq telnet log
permit tcp host 192.168.1.2 any eq 22 log
deny tcp any any log
access-list 1 permit 192.168.1.0 0.0.0.255
dialer-list 1 protocol ip permit
no cdp run
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
access-class TerminalAccess in
login
transport input ssh
scheduler max-task-time 5000
end
The route connects OK and give IP addresses by dhcp server.
I can ping 8.8.8.8. But ping 8.8.8.8 source 192.168.1.1  doesn't work.
show ip nat st
Total active translations: 0 (0 static, 0 dynamic; 0 extended)
Peak translations: 0, occurred 02:10:20 ago
Outside interfaces:
FastEthernet4
Inside interfaces:
Vlan1
Hits: 0 Misses: 0
CEF Translated packets: 0, CEF Punted packets: 0
Expired translations: 0
Dynamic mappings:
-- Inside Source
[Id: 1] access-list 1 interface Dialer0 refcount 0
Appl doors: 0
Normal doors: 0
Queued Packets: 0
show ip nat tr - empty.
Could you advise me something?
64 Replies 64
use the configuration below:
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
import all
lease 0 2
ip cef
no ipv6 cef
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
archive
log config
hidekeys
no ip address
duplex auto
speed auto
interface Vlan1
ip nat inside
interface Dialer0
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp chap refuse
ppp ms-chap refuse
no ip http server
no cdp run
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input ssh
end
Thank you!
Now ping 8.8.8.8 source 192.168.1.1 works, but ping 8.8.8.8 from client fails.
debug ip nat - shows nothing.
What else could cause this problem?
remove the two lines in bold from your config:
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
import all
lease 0 2
ip cef
no ipv6 cef
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
archive
log config
hidekeys
no ip address
duplex auto
speed auto
interface Vlan1
ip nat inside
interface Dialer0
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp chap refuse
ppp ms-chap refuse
no ip http server
no cdp run
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input ssh
end
I removed, it didn't help. Ping from route works, from client doesn't.
I made a few adjustments (in bold), I added an extended access list instead of a standard. If this doesn't work, we'll try a route map. Configure the below first...
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
import all
lease 0 2
ip cef
no ipv6 cef
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
archive
log config
hidekeys
no ip address
duplex auto
speed auto
interface Vlan1
ip nat inside
ip tcp adjust-mss 1420
interface Dialer0
ip mtu 1460
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp chap refuse
ppp ms-chap refuse
no ip http server
ip nat inside source list NAT interface Dialer0 overload
ip access-list extended NAT
 permit ip 192.168.1.0 0.0.0.255 any
no cdp run
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input ssh
end
if the previous doesn't work, configure the route map overload as below:
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
import all
lease 0 2
ip cef
no ipv6 cef
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
archive
log config
hidekeys
no ip address
duplex auto
speed auto
interface Vlan1
ip nat inside
interface Dialer0
ip mtu 1460
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp chap refuse
ppp ms-chap refuse
no ip http server
ip nat inside source route-map NAT_OUT interface Dialer0 overload
route-map NAT_OUT permit 10
 match ip address NAT
no cdp run
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input ssh
end
Nope. Pings from client don't work.
the problem might be related to the DHCP pool configuration. Try and remove the line 'import all', and add 'dns-server 8.8.8.8 8.8.8.4'
So:
import all
lease 0 2
should become:
lease 0 2
also remove the lines below from your configuration:
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
Again, nothing has changed.
Here is las configuration:
Current configuration : 1881 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
lease 0 2
ip cef
no ipv6 cef
archive
log config
hidekeys
no ip address
duplex auto
speed auto
interface Vlan1
ip nat inside
interface Dialer0
ip mtu 1460
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp chap refuse
ppp ms-chap refuse
no ip http server
no cdp run
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input ssh
end
you are missing the DNS part of the DHCP pool. Also, can you post the output of ;show ip nat translations'...
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
lease 0 2
ip cef
no ipv6 cef
archive
log config
hidekeys
no ip address
duplex auto
speed auto
interface Vlan1
ip nat inside
interface Dialer0
ip mtu 1460
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp chap refuse
ppp ms-chap refuse
no ip http server
no cdp run
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input ssh
end
I added dns-server.
Router#show ip nat translations
Router#sh ip nat st
Peak translations: 1, occurred 00:19:16 ago
Outside interfaces:
Dialer0, Virtual-Access1
Inside interfaces:
Vlan1
Hits: 10 Misses: 0
CEF Translated packets: 5, CEF Punted packets: 0
Expired translations: 1
Dynamic mappings:
-- Inside Source
[Id: 1] access-list NAT interface Dialer0 refcount 0
Appl doors: 0
Normal doors: 0
Queued Packets: 0
what is the IP configuration of your clients ? Can your clients ping the default router 192.168.1.1 ?
Clear the IP NAT translations (clear ip nat translation *), the try to ping 8.8.8.8 from a client, and check if there are eny entries in the NAT translation table.
Are these Windows clients ?
The client -Win7 gets 192.168.1.2
mask 255.255.255.0
default gate. . . . . . . . . : 192.168.1.1
DHCP-server. . . . . . . . . . . : 192.168.1.1
DNS-servers. . . . . . . . . . . : 8.8.8.8   8.8.4.4
I can ping 192.168.1.1 from client.
Here is client's route print output:
0.0.0.0 0.0.0.0 192.168.1.1 192.168.1.2 276
127.0.0.0 255.0.0.0 On-link 127.0.0.1 306
127.0.0.1 255.255.255.255 On-link 127.0.0.1 306
127.255.255.255 255.255.255.255 On-link 127.0.0.1 306
192.168.1.0 255.255.255.0 On-link 192.168.1.2 276
192.168.1.2 255.255.255.255 On-link 192.168.1.2 276
192.168.1.255 255.255.255.255 On-link 192.168.1.2 276
192.168.145.0 255.255.255.0 On-link 192.168.145.1 276
192.168.145.1 255.255.255.255 On-link 192.168.145.1 276
192.168.145.255 255.255.255.255 On-link 192.168.145.1 276
192.168.152.0 255.255.255.0 On-link 192.168.152.1 276
192.168.152.1 255.255.255.255 On-link 192.168.152.1 276
192.168.152.255 255.255.255.255 On-link 192.168.152.1 276
224.0.0.0 240.0.0.0 On-link 127.0.0.1 306
224.0.0.0 240.0.0.0 On-link 192.168.1.2 278
224.0.0.0 240.0.0.0 On-link 192.168.152.1 276
224.0.0.0 240.0.0.0 On-link 192.168.145.1 276
255.255.255.255 255.255.255.255 On-link 127.0.0.1 306
255.255.255.255 255.255.255.255 On-link 192.168.1.2 276
255.255.255.255 255.255.255.255 On-link 192.168.152.1 276
255.255.255.255 255.255.255.255 On-link 192.168.145.1 276
clear ip nat translation * didn't help.
sh ip nat tr     is empty.
