NAT external IP to internal IP when connected to the internal network.
FloFlex
We have on our internal network a CalDav server which is accessible from outside using NAT rules on our ASA 5506 firewall.
However, this CalDav server should be accessible from outside (working) and also from our internal network. The smartphones having the CalDav client application installed are always configured to point on the public IP of this server, but once the smartphones are connected to the internal network, they do not have access to the "public" server anymore. Then, I'm trying to figure out what would be the best practice (with the ASDM) to NAT the external IP to an internal IP when trying to access this server from the internal network.
Thanks in advance for you support,
Florian
Francesco Molino
Let's assume public ip is 1.1.1.1 and private ip of the server is 2.2.2.2. Also let's assume you have 2 interfaces: inside and outside.
object network PUB-SRV
host 1.1.1.1
object network PRIV-SRV
host 2.2.2.2
object network LAN-PCS
subnet 192.168.1.0 255.255.255.0
nat (inside, outside) source static LAN-PCS LAN-PCS destination static PUB-SRV PRIV-SRV no-proxy-arp route-lookup
Try it, replace with correct IPs info and let me know.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Hi Franscesco,
Thanks a lot for your reply.
I've tried your recommandation but it looks like their something else I have to resolve when looking into the log. Indeed, something preventing me to perform the transaction :
2 106001 192.168.1.59 59326 PUB-SRV 38443 Inbound TCP connection denied from 192.168.1.59/59326 to PUB-SRV/38443 flags SYN on interface localNetwork. I keep you posted.
something like the below should work as well (IP addressing is arbitrary obviously):
same-security-traffic permit intra-interface
interface GigabitEthernet0/1
nameif inside
security level 100
interface GigabitEthernet0/0
nameif outside
security level 0
ip address 100.100.100.1 255.255.255.252
object network WEBSERVER_PUBLIC
host 100.100.100.1
object network WEBSERVER_LOCAL
host 192.168.1.100
object service HTTP
service tcp destination eq www
object-group network LOCAL_HOSTS
network-object 192.168.1.0 255.255.255.0
nat (inside,inside) source dynamic LOCAL_HOSTS interface destination static WEBSERVER_PUBLIC WEBSERVER_LOCAL service HTTP HTTP
