NAT help
pmarques
Level 2
Level 2
Hi Community,
I'm trying to setup NAT for the following scenario with no success so far.
I need machine 10.5.2.33 to communicate with 189.23.0.85 and vice versa.
Only RT1 "knows" how to reach both sides.
I almost managed to have this working with the following configuration on RT1 but still not entirely functional. And that's why I need help sorting this one out.
NOTE: I'm using TCP port 445 for testing purposes between these windows machines.
RT1 relevant config:
interface FastEthernet0/0
ip address 10.17.8.100 255.255.255.0
ip nat inside
ip virtual-reassembly
interface FastEthernet0/1
ip address 192.168.138.86 255.255.255.252
ip nat outside
ip nat inside source list NAT_OUT interface GigabitEthernet2.138 overload
ip nat inside source static tcp 10.5.2.33 445 192.168.138.86 2000 extendable
ip route 10.5.2.0 255.255.255.0 10.17.8.254
ip route 192.168.0.0 255.255.255.0 192.168.138.85
ip access-list standard NAT_OUT
permit 10.5.2.0 0.0.0.255
permit 10.17.8.0 0.0.0.255
Hope the info provided is enough.
Thanks in advance,
Pedro
5 Replies 5
Julio E. Moisa
Please correct me but the diagram does not have the same IP addressing, well on your configuration you have configured the IP nat outside under the interface FastEthernet0/1, but your NAT statement is using a subinterface.
You could use: show ip nat translations  or  debup ip nat <acl> ; where the ACL could check the specific host.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Julio
Thank for the prompt reply. It is indeed a typo. It should be:
ip nat inside source list NAT_OUT interface FastEthernet0/1 overload
I will collect both outputs and share.
Hi Julio,
Here's the output from both show ip nat translations and debug ip nat. The following outputs are the result of a telnet 189.23.0.85 445 from 10.5.2.33. If i try to telnet to10.17.8.100 445 from the same machine nothing happens.
RT1#show ip nat tra
RT1#show ip nat translations
Pro Inside global      Inside local       Outside local      Outside global
tcp 189.23.138.86:445  10.5.2.33:445      ---                ---
RT1#debug ip nat
*Aug 31 13:13:07.639: NAT*: s=10.5.2.33->189.23.138.86, d=189.23.0.85 [461]
*Aug 31 13:13:07.639: NAT*: s=189.23.0.85, d=189.23.138.86->10.5.2.33 [612]
*Aug 31 13:13:07.639: NAT*: s=10.5.2.33->189.23.138.86, d=189.23.0.85 [462]
*Aug 31 13:13:28.411: NAT*: s=10.5.2.33->189.23.138.86, d=189.23.0.85 [467]
*Aug 31 13:13:28.635: NAT*: s=189.23.0.85, d=189.23.138.86->10.5.2.33 [626]
*Aug 31 13:13:37.643: NAT*: s=189.23.0.85, d=189.23.138.86->10.5.2.33 [627]
Hello
The example i provided should work however you are now showing addressing not shown on any of your OP and files.
Your outside interface is
ip nat outside
So with this new information are you double natting somewhere and if so you will need to staic nat on that device also.
res
Paul
Kind Regards
Paul
Hello
R3
ip route 0.0.0.0 0.0.0.0 fa0/0 10.17.8.100
R1
deny host 10.5.2.33  <--remove this if you wish this host to iniciate 445 connection to r2's host
ip nat inside source list NAT_OUT interface fa0/1 overload
ip nat inside source static tcp 10.5.2.33 445 192.168.138.86 445
res
Paul
Kind Regards
Paul
