NAT Interface Overload
clark white
Level 2
Level 2
Dear Experts,
I have a strange issue ,, my configs were working perfect on 12.4 when i changed the router 887 VA with an IOS 15.1 the NAT doenst works for internet traffic.
I have confgured the EZVPN client on my new 887VA router connecting to HO,the vpn is established perfect but the traffic for internet stops, when i remove the  crypto command from my outside interface it starts translating and the natting for internet traffic works fine.
35 Replies 35
Please find  the attached,
Dear Peter,
  • Going through ur previous email you mean to say that the client is only authentication by Group and not the Xauth, becuase once we include the KK group in the crypto isakmp profile client the authentication fails, if any of the client in production if it connection breaks it requires a authentication to connect back again if we keep the KK group in crypto isakmp profile client. so for this reason we exclude the authentication and authorization commnads from crypto isakmp profile command
  • Please correct me if the above understanding is wrong.
   match identity group cana
   client authentication list user
   isakmp authorization list group
   client configuration address respond
  • Below are the commands i implemented without changing the existing commands mentioned above. If i keep both will it effect the routers in production.as if now it is midnight so nobody is screeming may be tomorrow somebody face problem.
crypto isakmp profile KK
   match identity group KK
  • The router is not connecting to HO . i tried creating a int lo0 on client router and tried to ping 4.2.2.2 it is pinging perfect but not connecting to HO
Aug 29 21:59:45.427: %CRYPTO-6-EZVPN_CONNECTION_DOWN: (Client)  User=  Group=KK  Server_public_addr=
85.85.85.86
Aug 29 21:59:47.055: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Informational mode failed with peer at
85.85.85.86
Has the client's configuration been changed in any significant way?
No i did'nt changed anything
Experts
help please.
Clark,
In Dynagen, I have entered the configuration of your HQ as posted in your last reply, and the suggested configuration of the client, and I did not have issues connecting the client to the HQ - it required entering the username and pasword on the command line after issuing the crypto ipsec client ezvpn xauth command
Are you absolutely sure you have posted the correct HQ configuration and used the client configuration as suggested above?
Best regards,
Peter
crypto isakmp policy 20
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp client configuration group cana
key vpn
dns 10.1.1.2 4.2.2.2.
domain wr
pool ippool
acl 102
crypto isakmp client configuration group KK
key 123
acl 161
crypto isakmp profile l2l
   match identity address 0.0.0.0
crypto ipsec security-association lifetime kilobytes 536870912
crypto ipsec security-association lifetime seconds 86400
crypto ipsec security-association idle-time 300
crypto ipsec transform-set t-set esp-3des esp-sha-hmac
Dear Peter,
Sorry for the delay reply,
I have posted correct config for you only changes are public IP.
it required entering the username and pasword on the command line,
I  have to create username and password on the HQ router for  authenticating all the branch routers????, and on HQ this username and  password should be created in global mode??? and also in Branch routers where i have to apply the username and password.
Clark,
Yes - if you want to keep your requirement stated in an earlier post that the EzVPN shall also authenticate by username/password (the Xauth) and not just by the group name and shared password.
Yes - you will use the username user_name privilege 0 secret user_password global level configuration command to create these accounts.
If you want these Branch routers to authenticate automatically then this password should be stored in the crypto ipsec client ezvpn configuration section using the username user_name password user_password command. However, the HQ in this case must be configured with the save-password command in its corresponding crypto isakmp client configuration group section. Otherwise, the username and password will need to be input in the Branch router's CLI again and again after restart or connectivity loss using the crypto ipsec client ezvpn xauth privileged EXEC command.
Please note - the primary purpose of the Xauth authentication is to authenticate users, not routers. That is the reason that the username/password needs to be input repeatedly, as it is expected the user comes and goes. Routers are authenticated sufficiently using the EzVPN group shared key, or - if higher security is needed - using X.509 certificates.
Best regards,
Peter
Dear Peter,
This means the HQ router config will change all the 60 No's Branch routers have to manually visit and change the username and password. OOhhhhhhhhhh.. It is a very risky job production down and it should be done in midnight.
I dont want to do Xauth only router authentication then what i have to do. I have to remove the command crypto ipsec client ezvpn xauth from the client configuration
