NAT ip protocol 250
Hello All!
I have VPN aplication a that need access from outside to inside by IP (not tcp or udp) protocol 250.
Another words all trafic that have been received on outside interface protocol 250 need be forwarded to inside workstation.
If I use static one to one NAT all works fine.
ip nat inside source static 192.168.30.1 interface FastEthernet0/0
But I need forward incoming traffic for web smtp rdp and other applications to anorher distinations.
ip nat inside source static tcp 192.168.30.118 3389 interface FastEthernet0/0 3389
How I should configure router to pass ip 250 traffic?
Thank you very much
0 Replies 0
