09-25-2008 12:26 PM - edited 03-03-2019 11:41 PM
I have a strange issue. I use a Cisco 2811 router with dual ISP for failover.
ip nat inside source static tcp 192.168.1.2 110 interface FastEthernet0/0 110
ip nat inside source static tcp 192.168.1.2 443 interface FastEthernet0/0 443
ip nat inside source static tcp 192.168.1.2 25 interface FastEthernet0/0 25
ip nat inside source static tcp 192.168.1.3 3389 interface FastEthernet0/0 3389
ip nat inside source static tcp 192.168.1.2 3390 interface FastEthernet0/0 3390
Everyone can access the server 192.168.1.3 from outside using the PUblic IP address but when people VPN in and try to access 192.168.1.3 using the private IP address, it doesn't work. Here's the NAT ACL
ip access-list extended NATACL
deny ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
permit ip 192.168.1.0 0.0.0.255 any
192.168.2.0 is the VPN POOL address.
Any help on this would be really appreciated.
OJ
Solved! Go to Solution.
09-26-2008 05:28 AM
Using route map with static NAT translations feature was introduced in 12.2(4)T .
There is one more way to bypass static NAT which was used before the route-map feature but here you need to create a loopback interface.
1. create a loopback interface
interface loopback0
ip address 10.254.254.253 255.255.255.252
2. Create a access list statement where you permit Ipsec traffic
access-list 199 permit ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
3. Create a Route Map and route the Ipsec traffic towards loopback interface.
route-map nonat permit 10
match ip address 199
set ip next-hop 10.254.254.254
4. Apply Route-map on the inside interface of the router, where you have "ip nat inside" applied also.
interface inside_interface_name
ip nat inside
ip policy route-map nonat
Clear Nat translations: clear ip nat trans *
And then check .
Saju
Pls rate helpful posts.
09-25-2008 12:33 PM
OJ-
Here's the fix (applied it many times).
The hyperlink doesn't work, but copy-n-paste into the URL and it will.
and the referring document-
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a0080094634.shtml
Hope that helps.
09-25-2008 12:33 PM
You will have to bypass the static NAT for VPN traffic .
1. Define access-list to Deny VPN traffic
access-list 130 deny ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 130 permit ip 192.168.1.0 0.0.0.255 any
2. Define a Route Map
match ip address 130
3. Remove existing static NAT and add the Route map to the static NAT statement
no ip nat inside source static tcp 192.168.1.3 3389 interface FastEthernet0/0 3389
route-map nonat
clear translations : clear ip nat translations *
And check results for VPN users.
Saju
09-25-2008 07:00 PM
thanks for your response.
The command ip nat inside source static tcp 192.168.1.3 3389 interface FastEthernet0/0 3389
route-map nonat
does not work. However, if I take out
no ip nat inside source static tcp 192.168.1.3 3389 interface FastEthernet0/0 3389, I can access the server after I VPN in but not with the PUblic IP address anymore.
Any Idea?
Thanks again.
OJ
09-26-2008 05:28 AM
interface loopback0
ip nat inside
And then check .
Saju
09-26-2008 09:32 AM
I do have 12.4.5.17(t) IOS on my router.
The moment I use
IP nat inside static 192.168.1.3 route-map nonat
I loose connectivity to the router. I only have one public IP address. I want to use this IP address for
1. Direct access to the server.
2. VPN Access
3. Inside computers to NAT through address to go ouside.
4. Management of the router.
Can this be done using Route-map.
One question from the above configuration. The address of the LO interface .253 But when we set next-hop 10.254.254.254. Where does this .254 come from.
OJ
09-26-2008 09:45 AM
Good question 🙂 , i will try to answer. when we set next hop as 10.254.254.254 (it does not exist anywhere) but this makes the traffic to exit out of Loopback interface where there is no "ip nat outside " configured. Another good argument can be why we did not configure " set interface loopback0" why next-hop ? when you configure set interface , the traffic does not exit out of loopback interface .
I am sure somebody here can explain it better than me.
Saju
