NAT Issues
stephen.moss88
I am in the process of setup of a sample lab at my home.
I have my main ISP coming into my personal Linksys Wireless Router. This is being used until I have a stable environment. My family might kill me if they have no internet.
Network Topology
  • ISP (Google Fiber)
  • Linksys Wireless Router
  • Cisco 1841
  • Cisco 3750G V2
  • Test Machine
I have multi VLANS working with DHCP on a stick setup on the router. I'm guessing I have a NAT issue  because everything works but the internet. Any advice would be awesome.
milan.kulik
Level 10
Level 10
I guess you should put
ip nat inside
under each of your FastEthernet0/1.x subinterfaces instead of under  the main FastEthernet0/1?
Plus I suppose you will assign some ports to all VLANs (not only VLAN1 and 10) on your switch?
BR,
Milan
dukenuk96
Level 3
Level 3
Can you share full network diagram with port numbers?
milan.kulik
Level 10
Level 10
ip nat inside
BR,
Milan
stephen.moss88
Thank you much Milan. That was the issue. And yes I will be assigning the ports to different VLANS today. This was just a trial to get it working :)
Stephen
